  • Replies 51
Posted Images
I run a genuine JDM air freshner, does that count for something?
I wish I did... :P
P.S How do I fix the poll up?
P.P.S this might sound like the most random poll in the world, but believe me, there is a point to it all :(
I have air conditioning and ive got 260rwkw and with a simple tune I could get another 80rwkw with no issues.
There is no way I would ever think about disconnecting my air conditioning. If the air con is in the way then I would spend more time and money to work around it.
End of story. Air con is goood.
Got aircon but definitely would NOT sacrifice it as my car is black and would be an oven without it on a summers day! :P
Air con is a necessary evil for daily drivers.
How much power does it rob:
A. With the compressor working.
B. with the compressor clutched/freewheeling.
C. With the air con switched off.
I would have guessed at:
A. 3-5hp
B. 2-4 hp
C. 0-2 hp
In which case a fix up at brand X service station vs brand Y service station or 5psi more/less in your tyres would do similar things.
Does anybody really know?? I'd be interested to find out.
I don't know why people want to get rid of the ac. I mean with it switched off you're losing the amount of power it takes to spin a fan belt and idler. Bugger all.
Then the weight loss? Probably 20 kilos.
All this and then summer comes along and you'll have regrets. If you want more power look into engine upgrades I say.
I'm thinking in more of running shorter pipes to the intercooler.
Like the setup I've got in my R32 (SR20), but with the RB's the aircon gets in the way of this sort of setup as the intercooler needs to sit in between the radiator support :D
Greg
Are you going to stick a small supercharger in place of the A/C? I mean... I doubt anyone would get rid of a working A/C in a daily driver? There'd have to be a BIG benefit to justify removing it. Certainly not for the minimal power loss from just having it connected.
Keen to see what you guys are up to!
WD40... windows down @ 40 degrees :) seriously though, aircon is damn near a necessisty, keep it and run more boost to make up for the reduced power (you probly wouldnt notice it anyway if its only 5hp on a 350hp+ car, im assuming your project car will run this, if not more) :)
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
