  • Replies 51
Posted Images
I run a genuine JDM air freshner, does that count for something?
I wish I did... :P
P.S How do I fix the poll up?
P.P.S this might sound like the most random poll in the world, but believe me, there is a point to it all :(
I have air conditioning and ive got 260rwkw and with a simple tune I could get another 80rwkw with no issues.
There is no way I would ever think about disconnecting my air conditioning. If the air con is in the way then I would spend more time and money to work around it.
End of story. Air con is goood.
Got aircon but definitely would NOT sacrifice it as my car is black and would be an oven without it on a summers day! :P
Air con is a necessary evil for daily drivers.
How much power does it rob:
A. With the compressor working.
B. with the compressor clutched/freewheeling.
C. With the air con switched off.
I would have guessed at:
A. 3-5hp
B. 2-4 hp
C. 0-2 hp
In which case a fix up at brand X service station vs brand Y service station or 5psi more/less in your tyres would do similar things.
Does anybody really know?? I'd be interested to find out.
I don't know why people want to get rid of the ac. I mean with it switched off you're losing the amount of power it takes to spin a fan belt and idler. Bugger all.
Then the weight loss? Probably 20 kilos.
All this and then summer comes along and you'll have regrets. If you want more power look into engine upgrades I say.
I'm thinking in more of running shorter pipes to the intercooler.
Like the setup I've got in my R32 (SR20), but with the RB's the aircon gets in the way of this sort of setup as the intercooler needs to sit in between the radiator support :D
Greg
Are you going to stick a small supercharger in place of the A/C? I mean... I doubt anyone would get rid of a working A/C in a daily driver? There'd have to be a BIG benefit to justify removing it. Certainly not for the minimal power loss from just having it connected.
Keen to see what you guys are up to!
WD40... windows down @ 40 degrees :) seriously though, aircon is damn near a necessisty, keep it and run more boost to make up for the reduced power (you probly wouldnt notice it anyway if its only 5hp on a 350hp+ car, im assuming your project car will run this, if not more) :)
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
