Booked in my r32 gtst for a $14 pedders suspension check, seeing as I've only had the car for a week would like to know if there are any problems to be fixed.
Results were:
Shock absorbers:
Left front: 27
Right front: 27
Left rear: 22
Right rear: 24
Pedders stated new shocks are rated 22, so nothing needs to be fixed there.
Only problem were:
Upper inner bushers worn $137
Slight play lhs mounts moving
LAB $132
Wheel align $55
Total ~ $324
Should I go ahead and book the service with pedders?
Also spoke to the person about pedders extreme suspension vs japanese made, he says pedders australian built and made for aus conditions plus not as stiff as imported :(
Thanks
- Patrick
https://www.sau.com.au/forums/topic/132237-pedders-suspension-check/
what is a LAB?
For inner arm bushes you should check out whiteline or notlec adjustable camber bushes.
Alignment price is good for a 4 wheel alignment but make sure you get the other work done first
Pedders charge $110 for a 4 wheel alignment.
The above quote is just the front wheel alignment
For bushes & your suspension needs its hard to go pass Whiteline items. Also, if Pedders had some idea about the Skyline they would of advised you to have a 4 wheel alignment done. SydneyKid has listed - Centeline Thomastown; & Traction Tyre & Suspension Rowville, as reputable suspension places in VIC.
I took my GTR into Pedders up here for the $14 check & dropped a few comments as hooks-in-the-water to see if they'd bite & yep, they sure did!!
Firstly they wouldn't let me in the workshop to SHOW me what needed to be replaced, which to be fair is the letter of the law BUT then they came back with a list of needing to completly dis-assemble the rear-cradle & replace all the bushes along with the front steering-rack being shot & needing to be re-built or replaced. Stupid $$$ & 2wks later I could have my car back.....
I then took it to a mates workshop & put it on the hoist. The car needs a RH front tie-rod end, a front CV-boot & not a lot else. Whilst the rest isn't brand-new, it doesn't need replacing right now either.
Anyway that's my experience, make of it what you will
that's pretty cheap. most good place i know charge between 100 and 150 if we are talking:
adjust front toe
adjust rear toe
adjust front castor
adjust front camber
adjust rear camber
that's a fair bit of stuff to do, and after doing camber things must be checked again as it can affect castor. and after doing castor another check is required. so it takes time.
Mate you could take a new car their and they would say it would need changing. :P
When the inspection was finished, they left my car on the hoist and asked me to follow him into the workshop. He then showed me what was wrong and what needed to be fixed, then lowered the car and printed out the invoice etc.
Havent done anything yet, looking around at other options.
Pedders and my local import speciallist gave me an identical list of suspension issues, so I figured that what they were telling me was reasonable. Always get a second opinion if you think you're getting taken for a ride!
Or could it be that Pedders and my mechanic are conspiring against me?!?!?!
Mate you never know.
These pedders outlets are franchises and i spose its the luck of the draw of which one you take it too.
They probly get a 6 week training course of how too rob people legally and get thrown into the business without a clue. Some pedders may be good depends on the owners. All they want is profit which im sure everyone wants, but not robbing people they way they do it.
My experience never go back.
Edited by subzeroR33
But wouldnt Joe Blow who "specialises" in Skylines and other imports would wonna rip you just as much as Pedders in this case? At the end of the day, everyone wants to make money. If you really want to save a buck, become friends with a mechanic and get him to check your car over, this is the only way.
My family friend mechanic told me today that you dont need to machine all disk rotors when changing brake pads... often its not needed at all but 9/10 places will tell you to do it, why? more money for them.
I cant imagine how much chicks get ripped everytime they service their cars...
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
