Hi. after ironing out all the problems with this car, i am getting bored with the performance now :)
I see these aftermarket ecu's and stuff. These i have heard they need constant re tuning all the time. Are apexi safc worth me wiring in to the loom and bothering with? Plus dont have pwr fc budget. Any info please :rofl: cheers....
https://www.sau.com.au/forums/topic/133062-apexi-safc/
  • Replies 65
Posted Images
safc is a nice unit safcII is the later and better versionor youcould get the neo, which has colour lcd, but yeah they are all quite good a getting a/f's right on par but that is also there limitaion,so depending on what you plan to do to the car it willmake a noticble difference.
i have seen a few guys running 200rwkw give or take, using a safc
but all in allagood unit for its price.
cheers
https://www.sau.com.au/forums/topic/133062-apexi-safc/#findComment-2465658
I don't know how good the results would be for over all engine performance and response. Sure the peak power is good, but peak power is for only a split second of driving time, what about mid range and response? may well be an improvement on stock, especially if you have changed a few things.
When looking at the price though, I wonder... $350 for the unit, then say $150 for the tune... $500.... best case
$950 for the powerFC, $250 for a tune, $1200... best case.
I dunno, but too me, $500 is enough to not want to waste, but not enough short of $1200 to warrant the limited functionality and effect on your cars performance.
https://www.sau.com.au/forums/topic/133062-apexi-safc/#findComment-2466831
Installed an SAFC II myself a few weeks back, very little performance gains but you can lean it out if your running more boost and definiately save on fuel. Also has a knock sensor and air flow readings
little gain!? you must not have tuned it correctly... my dyno graph before and after produced a 20rwkw gain, alot of people with SAFC's have said they have achieved similar gains. I think its a good mod if you dont plan on doing extensive work. If you do the basic things like me; pod, exhaust, cooler, fuel pump, boost... then its perfect, i was able to get 192rwkw with the SAFC and 170 or so before it was installed.
https://www.sau.com.au/forums/topic/133062-apexi-safc/#findComment-2466948
what boost are you running?
did u really need to do fuel pump at this level?
https://www.sau.com.au/forums/topic/133062-apexi-safc/#findComment-2466957
156rwkw at 12 psi before SAFC and 155rwkw at 11 psi after SAFC. Turned down the boost slightly because fuel pump is shit. Probably over 160kw with a new fuel pump so yeah there is a gain in power. What correction numbers do you use? mine is around -10 on low throttle and over -20 on high throttle.
https://www.sau.com.au/forums/topic/133062-apexi-safc/#findComment-2467011
i installed an safc II not too long ago and i got considerable gains...was a faster all over the rev range and much more responsive due to better mid-range. However, of your a/f ratios are good then there is no need to get a safc.
Also, i think my car has got a little slower (still faster than before safc, but not as fast as when safc was first tuned). I was wondering whether this would be because the timing has been changed by the ecu again, resulting in less power?
https://www.sau.com.au/forums/topic/133062-apexi-safc/#findComment-2467878
i used to havee the oriiginal safc... tried to use i to lean out my car for emissions tests... everyone i went to told me to get a pfc or something similar!
i personally would not chose the safc, and regretted buying it! with the prices of pfcs these days, i'd go with that...
https://www.sau.com.au/forums/topic/133062-apexi-safc/#findComment-2516820
Cant remember but I brought it from www.greenline.jp als checkout www.nengun.com I find these to places cheepest for most japanese parts
cheers
Are these site trust worthy and is it in australian dollars cauz the prices seem too good to be true.
https://www.sau.com.au/forums/topic/133062-apexi-safc/#findComment-2541350
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
