  • Replies 59
Posted Images
Hi I was wondering if low 12 sec qtr mile passes are possible with the stock turbos that come on the rb25's?
What are the best times you guys have got using the stock turbos and what other mods?
i think i high 12's 1/4mile is achieveable if you can drive...
i was running 13.8 @ 106mph with not alot of power.
on that night a wrx with the same mph, was running 13.1 and i know of a soarer that has run 12.9 with 108mph...
so if you can get your car off the line and have good gear changes, a high 12 is do able :O
good luck :spank:
Its definately possible but has to be a perfect run. I ran many low 13's, 13.0,13.1 and then 12.98@107. That was with street tyres and even a SAFC and no PFC.
hi can you tell me all the mods you had when you did the 12 and the boost
  • 4 months later...
Would an R34 GTT with the following mods -
Split dump / front pipe
Metal high flow cat
3" cat back exhaust
Apexi filter
and running stock turbo at 11 to 12psi
Decent 225 street tyres
- and some good driving be able to get a 13.0 sec pass? Also would getting a GReddy E-Manage Ulimate and a good tune with the mods above push the car into the high 12's??
Ta ;)
There is no reason you cant get 13.0 or close to it.
It comes down to driver skill/car setup.
More runs you have, more expirience you'll get.
Although 225's are a little skinny, but its just practice
You didnt have 208rwkw ;) Not with 103mph at least anyhow.
With 220rwkw i was doing 109mph 12.9 (not stock turbo) with 2.2 60ft's.
Your 60ft isnt too bad for street tyres, maybe you missed a gear or something? If you didnt... then the car just doesnt have the power the dyno reads IMO.
13.5 is still a good effort though with 103mph for whatever power the car has
R33 RB25DET standard turbo running 10 PSI full 3 inch exhaust, pod filter, just jap front mount, running on 19/30/265 Nankangs atleast 50% worn (on the inside anyways)
13.648 @ 165.14 K/mh roughly 102MPH
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
