Well I just did the conversion and yeah, as Simon said, the gearbox crossmember lines straight up to the factory holes. Mine was originally an auto, and I dont know what cross member I'm using... Didn't line up with the RB20 gearbox though. Engine is ~30mm lower and have had no issues with the box fouling on the tunnel or anything like that. :(
  • Replies 188
Posted Images
Well I just did the conversion and yeah, as Simon said, the gearbox crossmember lines straight up to the factory holes. Mine was originally an auto, and I dont know what cross member I'm using... Didn't line up with the RB20 gearbox though. Engine is ~30mm lower and have had no issues with the box fouling on the tunnel or anything like that. :rofl:
bit off topic but i know u have aftermarket sway bars so u may be able to help. i dropped my motor the same amount as what cubes pdf says and i cant fit an aftermarket swaybar (the sump fouls) how'd u go?
Did you do yours or did shaun lower it?
Looking at yours its definitely sitting lower than mine. :rofl:
As salad said to me.. Grab a bit of plate cut it to shape and space the swaybar chassis mounts down slightly so the aftermarket bar fits.
using the rb20det sump provides more clearance around the sway bar area.
25 shifters are a lot longer then a 20 shifter... i find it quite annoying acctually and i'll prob fit a 20 shifter back in to my car, Too many mis shifts from 2nd to 3rd while drifting on the track... im not THAT retarded but the shifter makes me feel like a doofus every time! lol
Im very surprised you didnt have to reduce the tailshaft length... mine simply would not fit! oh well its in now lol
cant use a rb20 shifter in a 25 box unfort
the balls on the end of the shifter are much bigger on the 25
20 shifter will just float around in it
You sure? Mine sits in there pretty nicely.
I dont think the RB20 sump offers any more clearance for the sump, the swaybar seems to be fouling at the front where the RB30 and RB20 sumps are the same shape.
I will just be spacing the swaybar down to make it fit, shouldn't have to go too much, almost fits (stocker) as it is, and it's pretty low as is!
cept it only has 2 wires...and the r32 speedo is mechanical
I know the 32 speedo is mechanical i was thinking of adapting a 33 speedo into a 32 gauge cluster. Having only 2 wires makes it a magnetic inductance sensor. the 33 clusters only have one signal in which means there is something else between the sensor and cluster, probably a BCM of some sort making it just about impossible to use the sensor and factory speedo.
  • 4 weeks later...
How would one go about hooking up the R33 eletric drive to an APEXi RSM?
See my speedo hasnt worked for a while because the plastic attachment into the back of the speedo has shattered after I put too much glue in it and forced it back on too hard. I would need to do the navara speedo drive bit and get a bit made up for the cable to speedo. Wouldnt it just be easier for me to hook up the R33 speedo drive and use the signal from that to operate a Rev/speed meter???
Anyone know how to get the R33 speedo drive to send a signal???
Thanks
would love to know the location of this speed sensor - attached
one day i will have to try and trace the 2 wires from the rb25 box to the cluster to see if the conversion of the signal is done inside the cluster or externally.
So are you saying its only two wires from the R33 speedo drive that then go into another device and get turned into a single wire that goes to the ecu and speedo?
thats what i was thinking about finding out
the wire 53 speed wire is the one people cut to remove the 180km limiter
so this external box (in the pic) is either the dash cluster or another box in the loom somewhere.
if anyone could get the entire workshop manual for these cars like the one i have for a 180sx which shows every wire and where it is in the car it would be alot easier to work out
Getting tail shaft made next week but still waiting on gearbox delivery so can anyone tell me the length from diff to gearbox?
Mine was a manual if it makes a difference.
Thanks,
Daniel
so will the drive send a signal if its just hooked up to 12v and earth?
If it does then I should be able to use that signal for a aftermarket speedo device (apexi RSM or AVC-R)
i tried doing this with mine and it didnt work :P so i sold the rsm and got a navara drive
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
