obviously lighter cam gears would be better, hey? less rotating mass, and all that. Means less torque, but better revability, ive been told. Thats flywheels, anyway. Does it matter much with cams?
I always thought that lightend flywheels make no difference to power and torque? :D
https://www.sau.com.au/forums/topic/134707-cam-gears/#findComment-2503831
A lightened drivetrain wil rev more freely, meaning basically that you will speed up quickly. Imagine spinning a light bicycle wheel, campared to spinning a heavy car wheel. The light wheel is easier to get up to speed, but has less momentum, so wont spin for as long, provided the resistance and friction was the same as the heavier car wheel. Hence the lightened flywheel, and carbon driveshafts, lightweight racing wheels etc.
Less weight will give you better acelleration, but you lose torque, because there is less momentum in the engine, and in some cases youll actually perform less ie slowing down when you come to a hill, due to reduced inertia in the rotating mass of your engine. all physics, dude.
I didnt think something so small as a cam gear would matter much though...
Edited by qikstagea
https://www.sau.com.au/forums/topic/134707-cam-gears/#findComment-2503844
KEWL so seeing as power is the rate at which you do work ie torquexrpm(laymans terms i know multiplying rpm by torque wont give you kw) and adding heavyer stuff to the rotating mass gives me more torque(apparently according to you) howmuch extra torque and power do you think i will get from adding an extra 20kgs to my flywheel??
Did you ever consider the losses involved in getting the rotating mass to turn adding weight to the rotating mass does nothing for the engines output torque or power just makes the enging take longer and more force to wind down which i quess can be considered torque but not the torque we are interested in...i think thats enough torque on talk or was it the other was around.
Edited by otto
https://www.sau.com.au/forums/topic/134707-cam-gears/#findComment-2504191
Also, I don't know the difference but the HKS ones are made of Duralumin and Nickel whereas the Tomei's are 100% Duralumin.
EDIT: just did a quick search and Nickel is actually stronger than Duralumin on the 'Vickers Hardness' test. 638MPa compared with 450MPa respectively.
https://www.sau.com.au/forums/topic/134707-cam-gears/#findComment-2504372
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
