Hey guys,
just want to throw some ideas around about the sever issues my friends car is now suffering after having a pcf installed and tuned at a fairly respectible brisbane workshop.
upon picking the car up my mate was told that they could not tune it to 11 psi as promised (std 33 turbo) as the actuator was screwed.. Now it was boosting up fine before taking it to the workshop - 8-9 psi arround 3k rpm as expected via a turbotech.
he drives it home and says car is running shit and lacking in power. Dyno sheets show 189 rwkw and good air fuel ratio. Now there is no torque graph, which i thought was strange? hiding something maybe.
anyhow full boost is not not made till arround 4-4500k rpm.. and it has been tuned to only run about 7 psi tops..
also car has all supporting mods, brand new fuel pump, fmic, pod full 3 inch zost with hiflow cat and now the pfc.
so i take it for a drive. strange rattle noise round the exhaust\turbo area.. lacking power for sure, boost does not hit hard. now we get home and let it idle. i can hear a rattley noise from arround the turbo exhaust housing when giving her a little rev. exhaust note sounds shit now aswell and not tough.. not to mention at idle she is blowing loads of black smoke and smeels badly like fuel.. and does not have a nice smooth idle. very up and down and just sounds wrong..
so from the above anyone got any clues as to what might be the problem. I am thinking possible exhaust wheel damage on turbo, hence rattles around the exhuast housing of the turbo..
Now if this is the case, would u not think a professional workshop would have known this and offered some advice more then just "mate your actuator is stuffed so it is not boosting properally" in which casue u would think they would replace it at a fee instead of trying to sell u a 3 grand turbo.
any ideas fellas
https://www.sau.com.au/forums/topic/134855-power-fc-r33-problems-help/
yeah its possible it blew on the dyno
mine died on the street under load but it could fail at any time
the parts to replace it are about $100 all up
but u have to pull the turbo off, my dump gasket died
but we replaced all of them cos it was off and easy to do
Only way is to get it on a dyno and have a gander at the AFR's and the smoothness of the graph itself.
There isnt anything "dodgy" about not showing the torque figures on a dyno sheet mate
If the exhaust wheel was damaged and "rattling" around, it wouldnt be there now. It would have flown off the shaft.
Have you even spoken to the workshop the tuned it?
If it is indeed a manifold gasket, its no-ones fault. They get old and perish. Nothing you can do about it
umm maps a a biatch to type up.. i kinda have the written down, might take a pic..
i noticed all the airflow settings are 100 percent..
inj maps.. from 1x1 to about 5x5 it os 100.. from six x six up a bit it is at the 119 mark and at 20 x 20 she tops out at 123.
hope that kinda makes sense. try and get a pic...
only reason i thought no torque graph was suss, is cause the car has definately lost torque. but according tot he dyno sheets it has gained 10 kw top end and lost 3 psi of boost after the tune???
yeah does make sense, maybe we blew the gasket taking it for a drive after we got it back..
would the blown gasket cause shite loads of black smoke on idle though??
boost climbs but just does not snap up of full boost, just climbs slowly..
and nismoid, no have not spoken to the workshop yet as just the car back at 5pm, they closed up etc, so we'll speak to them tomorrow..
in no way am i tryin to blame them, just trying to figure out the chain of events that led to the car now barely running.
still the work shop said the actuator was fubared?? how many r33 stock turbos have stuffed atuators? is this common?
Would just like to stress the intention of this post is not to bag out any particular workshop, and i have not mentioned any names etc, so no need to get upset.. You know who you are..
One would imagine though if they took their car to a good workshop for a apexi power fc install and tune they would either come out with a smile from the new tune (from what I have read eveyone else raves about the powerfc) or an eplanation on why their car now runs like a pile of crap...
car is getting checked out soon.
Glad your not trying to bag any work shops as this problem was definatly not the work shops fault. I don't understand how you can drive away with dyno graphs and a car that runs fine and then when it starts playing up you blame the tune, it just doesn't work this way. if there is something mechanically wrong with the car, no amount of tuning is going to fix it.
For those of you who are reading the thread, someone had been playing with the hand controller and had selected the "nismo option" AFM instead of the normal r33 GTST one, which caused the car to run like a piece of crap. With a new set of plugs and the correct AFM selected the car now runs fine again but the turbo is definatly on the way out as it's a little noisy (as was explained to the customer when he picked up the car).
It's very frustrating when you go out of your way to look after the customer and pay for the tow truck back to the work shop and it's due to someone playing around with things they don't know about. At least the car is running well again now which is the main thing I guess!!!
good to see it resolved and another case in point why if you dont know what you are doing the only screens you should should be looking at on your PFC HC is the monitor or sensor check screens.
  • 6 months later...
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
