Hey guys,
just want to throw some ideas around about the sever issues my friends car is now suffering after having a pcf installed and tuned at a fairly respectible brisbane workshop.
upon picking the car up my mate was told that they could not tune it to 11 psi as promised (std 33 turbo) as the actuator was screwed.. Now it was boosting up fine before taking it to the workshop - 8-9 psi arround 3k rpm as expected via a turbotech.
he drives it home and says car is running shit and lacking in power. Dyno sheets show 189 rwkw and good air fuel ratio. Now there is no torque graph, which i thought was strange? hiding something maybe.
anyhow full boost is not not made till arround 4-4500k rpm.. and it has been tuned to only run about 7 psi tops..
also car has all supporting mods, brand new fuel pump, fmic, pod full 3 inch zost with hiflow cat and now the pfc.
so i take it for a drive. strange rattle noise round the exhaust\turbo area.. lacking power for sure, boost does not hit hard. now we get home and let it idle. i can hear a rattley noise from arround the turbo exhaust housing when giving her a little rev. exhaust note sounds shit now aswell and not tough.. not to mention at idle she is blowing loads of black smoke and smeels badly like fuel.. and does not have a nice smooth idle. very up and down and just sounds wrong..
so from the above anyone got any clues as to what might be the problem. I am thinking possible exhaust wheel damage on turbo, hence rattles around the exhuast housing of the turbo..
Now if this is the case, would u not think a professional workshop would have known this and offered some advice more then just "mate your actuator is stuffed so it is not boosting properally" in which casue u would think they would replace it at a fee instead of trying to sell u a 3 grand turbo.
any ideas fellas
https://www.sau.com.au/forums/topic/134855-power-fc-r33-problems-help/
yeah its possible it blew on the dyno
mine died on the street under load but it could fail at any time
the parts to replace it are about $100 all up
but u have to pull the turbo off, my dump gasket died
but we replaced all of them cos it was off and easy to do
Only way is to get it on a dyno and have a gander at the AFR's and the smoothness of the graph itself.
There isnt anything "dodgy" about not showing the torque figures on a dyno sheet mate
If the exhaust wheel was damaged and "rattling" around, it wouldnt be there now. It would have flown off the shaft.
Have you even spoken to the workshop the tuned it?
If it is indeed a manifold gasket, its no-ones fault. They get old and perish. Nothing you can do about it
umm maps a a biatch to type up.. i kinda have the written down, might take a pic..
i noticed all the airflow settings are 100 percent..
inj maps.. from 1x1 to about 5x5 it os 100.. from six x six up a bit it is at the 119 mark and at 20 x 20 she tops out at 123.
hope that kinda makes sense. try and get a pic...
only reason i thought no torque graph was suss, is cause the car has definately lost torque. but according tot he dyno sheets it has gained 10 kw top end and lost 3 psi of boost after the tune???
yeah does make sense, maybe we blew the gasket taking it for a drive after we got it back..
would the blown gasket cause shite loads of black smoke on idle though??
boost climbs but just does not snap up of full boost, just climbs slowly..
and nismoid, no have not spoken to the workshop yet as just the car back at 5pm, they closed up etc, so we'll speak to them tomorrow..
in no way am i tryin to blame them, just trying to figure out the chain of events that led to the car now barely running.
still the work shop said the actuator was fubared?? how many r33 stock turbos have stuffed atuators? is this common?
Would just like to stress the intention of this post is not to bag out any particular workshop, and i have not mentioned any names etc, so no need to get upset.. You know who you are..
One would imagine though if they took their car to a good workshop for a apexi power fc install and tune they would either come out with a smile from the new tune (from what I have read eveyone else raves about the powerfc) or an eplanation on why their car now runs like a pile of crap...
car is getting checked out soon.
Glad your not trying to bag any work shops as this problem was definatly not the work shops fault. I don't understand how you can drive away with dyno graphs and a car that runs fine and then when it starts playing up you blame the tune, it just doesn't work this way. if there is something mechanically wrong with the car, no amount of tuning is going to fix it.
For those of you who are reading the thread, someone had been playing with the hand controller and had selected the "nismo option" AFM instead of the normal r33 GTST one, which caused the car to run like a piece of crap. With a new set of plugs and the correct AFM selected the car now runs fine again but the turbo is definatly on the way out as it's a little noisy (as was explained to the customer when he picked up the car).
It's very frustrating when you go out of your way to look after the customer and pay for the tow truck back to the work shop and it's due to someone playing around with things they don't know about. At least the car is running well again now which is the main thing I guess!!!
good to see it resolved and another case in point why if you dont know what you are doing the only screens you should should be looking at on your PFC HC is the monitor or sensor check screens.
  • 6 months later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
