HICAS vs No HICAS (Track use)
34 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey guys,
Ive just bought an 1992 R32 GTSt and am planning to take it to track for a bit of fun. It has HICAS installed at the moment which as far as I can tell works fine. (HICAS light comes on sometimes due to a bad contact somewhere - which goes away when you spray contacts with contact cleaner).
Anyways real question is what do you guys think? Would I be better off removing the HICAS? I personally think its crap but have had a few friends (who have had 4WS cars but dont know anything about skylines) tell me that maybe it just takes some getting use to....
I think its fine for the road but dont like it when turning under speed - so whats the verdict?
Comments welcome
Edit: One friend even suggested trying it with HICAS atleast once which is also an option i suppose...
Edited by ZENNON
You can keep it for a little while. I have been out with HICAS still on, didn't kill me..
The general consensus is remove it when you can for more predictable handling, but it's not mandatory if you are just out there to have some fun.
it's pretty easy. unless u did wat i did and didnt crack the 2 nuts before removing the 2 main bolts that hold it inplace :wave:
ah yeah ive heard people complain about that... you wouldn't be able to show me in a pic which nuts to crack before i undo which bolts...
would be very helpful
I rekon leave it on, go to track day see how it goes, then if it feels funny take it off for the next track day. This way you will be able to feel exectly what the change does.
Sam
Yeah what Gordo said. HICAS makes it a bit difficult to hold a precise line mid-corner (because the computer decides it wants to change the angle of the back wheels :wave: ) and can make it feel a bit nervous. That said, to the day I sold it my Skyline still had the HICAS connected and working, once I got used to it I just let the rear end wander a little, and made small steering adjustments to keep my line accurate. It does feel a bit wierd but you can drive around it.
Also consider though, the effect a lock bar may have on your insurance/wallet. This is second hand info so I'd be checking it yourself if you're concerned, but I'm told lock bars are illegal because they are a modification to the steering systems. You could be defected for it, and if you crash you may not be covered. I never followed this up myself because I had no need to, but it might be worth checking :D
thanks for the advice guys
Yeah what Gordo said. HICAS makes it a bit difficult to hold a precise line mid-corner (because the computer decides it wants to change the angle of the back wheels :no: ) and can make it feel a bit nervous.
Yeah... I think Ill see how I go but Im inclined to remove it...
Also consider though, the effect a lock bar may have on your insurance/wallet. This is second hand info so I'd be checking it yourself if you're concerned, but I'm told lock bars are illegal because they are a modification to the steering systems. You could be defected for it, and if you crash you may not be covered. I never followed this up myself because I had no need to, but it might be worth checking :kiss:
Nah itll be fine! :laugh:
where do people get the lock bars from? I got an r33 and was going to take mine off but didnt really know where to get the lock bars made up. I've taken corners at high speeds before and i think the skyrice handles fine even with the hicas
I really had no problems with the handling under hicas, I just didnt like a computer cutting in on my driving, I used the Tomei kit, which gives you the option of going back quite easily for the 33, with the 32s the Hicas is hydraulic and a weight saving can be had by its removal.
If you want full control then remove hicas...
If you want some help then leave it in...
I used to race go karts and hicas just messed with my driving style so i removed it quick smart... Im just used to not having it so it was an easy decision for me... Also it does scuff your tyres on the inside edge on the rear faster then with out hicas...
hicas is 4 wheel steer...
Well not really 4 wheel steer just more like the rear wheels moving slightlly a couple of degres to help through corners...
There are 2 types of hicas, there is the one where the whole rear suspension moves like found in the HR31's and then there are ones with an actually second steering rack just for the rear wheels like in the 32,33,34...
Personally i dont like hicas...
My bf purchased a tomei lock out kit for his 33 off nengun.. as his car was actually CRAB WALKING as a result of of the hicas LOCKING ON in one direction..
It's all been installed now.. and car drives straight! :P
In 32's it is much easier to fix as the hicas is mehanical where as the 33's have an electrical one.
I drove my 32 with the hicas light on and it was gay to drift.. as the back wheels had a mind of their own!
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
