I think this topic has come up before, and no one had done it back then. Personally I don't think it would be worth while. You lose your boot space, your fuel consumption increases, your power levels decrease. For a custom system on a skyline, I'd guess the cost of install vs. the fuel savings would take 2-3 years to pay itself off, which in my mind isn't worth the loss of performance and practicality.
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2600978
I think by and large, owners of skylines have resolved themselves to the trade off of premium fuel prices and amount of use, with the fact of owning the car itself.
Read= If you've bought a skyline, fuel prices aren't your first priority.
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2605776
Doesn't anybody listen to our politicians and in particular, little Johnny himself?
LPG is a panic attack idea when oil gets expensive, but as is the current situation, little Johnny is throwing $2000 at us to convert to LPG, but there is about a 9 month waiting list to get it fitted to anything, let alone a Skyline.
The biggest problem facing a conversion like this is it's compatability with the stock ECU and not all cars are compatible.
My 1UZ for example, is not compatible and anything fitted with any UZ engine, I know not Nissan, (Landcruisers etc with 2UZ & 3UZ) they have not yet designed a compatible system for this engine derivative.
Now! getting back to the man, little Johnny, he has been making noises for the past 3 years about placing the excise that's on petrol, onto LPG, so in time your going to be paying nearly the same for LPG as petrol, so WHY WOULD YOU BOTHER, when LPG burns so much hotter, as it's dryer and you use 20/30% more in quantity.
Just my 2 bobs worth.
Cheers, D
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2608734
its also like 103 ron fuel and if setup and tuned correctly can run better and hell of alot cleaner. also ghosterider there are several soarer v8's in the eastern states that have dedicated gas setups and a few cars with 1uz conversions running gas too. sure there all custom but nothing is impossible. it all comes down to who u know and how cheap u can get the install done
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2608752
You can do it, they're doing it to XR6 turbos in SA using pretty advanced LPG injection management system coming from Italy.
Get a hold of issue 101 of Zoom, its the June issue for 2006, theres an article about it. The place in Adelaide who can fit them is called Adelaide performance Engineers ph: 08 8277 5688
Edited by MintR33
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2611467
As has been said, Why would you bother???
The point I was trying to make, apart from compatability is this.
Conversion cost, no matter how or where is about $2000.00 and as LPG burns so much hotter, irrespective of octane rating, it uses more fuel by about 20% and therefore, for the average person it's going to take 2 or maybe 3 years to recover the cost of the conversion and by then, IF the libs are still in power then, you can bet your ass that the excise will be on it and the price will be much the same as petrol per litre.
Cheers, D
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2611835
In the article, they were able to make more power with LPG, and also overcome the increase of fuel consumption by running the LPG in a similar fashion to that of a normal fuel injection system. Apparently the current common design for LPG systems is based on a design founded in the 1950's and is similar by comparison to a carburettor type set up, so as you can gather - is quite inneficient by todays standards.
Having said that, im not an expert on the topic, and am only re-iterating what I can remember from the article :)
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2612137
yip. i agree
haha yeeepp
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2616577
I remember something about a standard option in xr6t's where you could purchase an LPG only version from factory. Had different pistons, slightly worse k's per litre as with all gas machines and had slightly less power but lasted muuuuch longer than any conversion ever will... gas converted engines seem to always need rebuilds muuuuch sooner. but admitedly this is based of 2L conversions the old man an I did on some toyota's, read multile hiace vans a few ford taxi's 1 4.1L s pac and 3 * 4L a somethings and a izusu light truck. also had a few done by other mechs an they were pretty practised on half and full conversions which did last a few years.
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2618081
personly id love to run a few experiments with a decent "gasresearch" setup.
id love to money permitting, be able to go twin 510cfm carbs.
last time i was looking the biggest gas injectors u could get were like 93cc which are equal to like 400cc petrol injectors. so unless u ran gas injection and richend it right up with say a 500cfm gas carb.
i dunno its all theory atm. im still trying to get my mate to set up an account with gas research and there suppliers, which would enable access to all the prinz gas injection parts.
chris
https://www.sau.com.au/forums/topic/137866-lpg-conversion/#findComment-2618993
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
