Just for a laugh.
1985 honda civic
890kg
1.6l DOHC ZC (not vtech yo) jap spec engine implant. 130HP at the crank from factory.
Mods: Extractors
rev cut 7500
15.5 down at WSID
100HP atw (75kw) lol at R31 club dyno day
Don't have it anymore.
i got a chrysler gallant
its got a custom exhaust (i cut it myself)
single down drought carbie(vacuum secondaries dont work)
and blown piston ring
"power" my guess bout 30kw at the rears lol
  • 1 month later...
Model - Swift
Engine - G13B
Modifications - Extractors, exhaust, cold air intake, BD14 cams, cam gears, Enlarged throttle body, group A chip, remapped ecu, dog box, msd coil set,
Dyno tune results 54kilowats before, 88 kilowats after
there was man other mods i just forget,
high 14 pass.
  • 3 weeks later...
put the pulsar on my mates dyno last night. made about 82kw, about 2kw down on what it made on a different dyno about 6 years ago. plenty of power left in it though. AFR's are mid 11's. now to convince the missus to let me put a nistune on it.....
  • 4 weeks later...
Engine:VQ35DE
Car: V35 Skyline Coupe
Mods: Z-tube and pop charger, Plenum spacer.
Power: 177rwkw.
Putting the Exhaust Headers on monday and a grounding kit. Will do a new Dyno run sometime next week. :P Hopping for 185rwkw
Finaly got the car on the dyno after getting the extractors and light wieght pulleys.
191rwkw now. Pushing for 200 :rofl2:
  • 3 weeks later...
  • 1 month later...
Some history on the RB20DE in the rally car:
Come a long way from it's first run of 97.5kw!
Spec's are:
RB20DE (235,000km)
Independent throttles (4AGE)
Ported head
Cams (270 or 280° can't remember)
Link G4
8,400rpm Rev limiter inguaged 4176 times in 2 years. That's not counting bouncing off the limit either. Rev it much?! :)
Z32 NA with exhaust/extractors/pod/chip yielded 240kw
My R32 with similar mods dynoed 222kw.
Battling to extract more though.
Errrrm...i think you were meant to say horsepower...240rwkws is somthing like 320-330kws at the flywheel.
I think he's just talking crap as a Z32 NA will all that wont make 240rwhp/rwkw in any case.
Rb30e
Today I made:
97.5rwkw @ 120kph
321nm @ 88kph
Rev Limiter @ 6500rpm
Specs:
Stock RB30E
Stock Timing (+15)
91 Fuel
Extractors & 2.5" Exhaust, Stock Cat & 1 Muffler Before Diff
3" Intake Pipe, Cheap Pod, Custom Airbox & CAI.
Going to run it on 98 Fuel Next time & +20 Timing, aiming for 100rwkw, also need to sort out the issue with it running rich.
  • 4 weeks later...
94 r33
rb25de
stainless steel extractors, cat back, apexi pod.
95.7rwkw...
update today i got 101.7rwkw with new catbak and timing advance in 4th gear run
what size exhaust do you have from the headers? and what size from the cat back?
  • 1 month later...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
