  • 1 month later...
I hope someone can help.
HR31skyline GTSX black over grey.
I think the code is 543G. Unsure how to decipher the code. I think the black is the 543 and the G is for grey? I have no idea what grey to tell theainter, I used the link that someone posted a few pages back but there were no listing for skylines this old.
Looking to get my bumpers fixed up and painted and eventually the rest of the car. Last shop in Melbourne didn't bother matching the paint, just used a gloss black with shitty glitter in it.
Edited by FordyR31
Mine is Red Pearl Metallic factory color and it says AH3 G on mine. Maybe the G means pearl metallic? otherwise 543 with a nice clear coat is your colour
Edited by IM-32-FK
  • 1 month later...
just getting away fron thr r series cars trying to fine the code or colour name of a 1998 pulsar q remember the old bright blue colour i have a vin but no code any help would be great
link to colour im after http://www.graysonline.com/lot/0002-3003502/motor-vehiclesmotor-cycles/1989-nissan-pulsar-q-hatch wanna do something with it on a r33 sedan think it might look great and diffrent
cheers ash
  • 5 weeks later...
I have a terrible time trying to find the color code for my Stagea autech version 260RS series 1 1997. It is some kind of white pearl. On the chassie plate it says WK1 but I got the painter to do samples and that color does not look right. Engine number etc is not correct either. I figgured out that Autech did not remove or change it when they modified the stageas to the autech 260rs versions. That is why the color code doesn´t match.
PLEASE HELP!!!
  • 5 months later...
I'm trying to find out what years Nissan Skyline V36 Coupe used the colour code KAD. It appears it's been around for a while in the USA G series, but I can't confirm what years for the Japanese Skyline.
It's also being used on the R35 GT-R and I think the 370Z
If anyone can help I would appreciate it heaps. As I'm trying to import one in that colour.
Cheers,
  • 2 months later...
  • 7 months later...
hope this is the appropriate section to post......
just trying to suss the factory under bonnet colour for my gun metal grey R32 GTR....
I know the engine bay is satin black but is that also the same for under the bonnet or should it match the exterior colour of the bonnet (gun metal grey?)
Cheers!
  • 11 months later...
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
