  • 1 month later...
I hope someone can help.
HR31skyline GTSX black over grey.
I think the code is 543G. Unsure how to decipher the code. I think the black is the 543 and the G is for grey? I have no idea what grey to tell theainter, I used the link that someone posted a few pages back but there were no listing for skylines this old.
Looking to get my bumpers fixed up and painted and eventually the rest of the car. Last shop in Melbourne didn't bother matching the paint, just used a gloss black with shitty glitter in it.
Edited by FordyR31
Mine is Red Pearl Metallic factory color and it says AH3 G on mine. Maybe the G means pearl metallic? otherwise 543 with a nice clear coat is your colour
Edited by IM-32-FK
  • 1 month later...
just getting away fron thr r series cars trying to fine the code or colour name of a 1998 pulsar q remember the old bright blue colour i have a vin but no code any help would be great
link to colour im after http://www.graysonline.com/lot/0002-3003502/motor-vehiclesmotor-cycles/1989-nissan-pulsar-q-hatch wanna do something with it on a r33 sedan think it might look great and diffrent
cheers ash
  • 5 weeks later...
I have a terrible time trying to find the color code for my Stagea autech version 260RS series 1 1997. It is some kind of white pearl. On the chassie plate it says WK1 but I got the painter to do samples and that color does not look right. Engine number etc is not correct either. I figgured out that Autech did not remove or change it when they modified the stageas to the autech 260rs versions. That is why the color code doesn´t match.
PLEASE HELP!!!
  • 5 months later...
I'm trying to find out what years Nissan Skyline V36 Coupe used the colour code KAD. It appears it's been around for a while in the USA G series, but I can't confirm what years for the Japanese Skyline.
It's also being used on the R35 GT-R and I think the 370Z
If anyone can help I would appreciate it heaps. As I'm trying to import one in that colour.
Cheers,
  • 2 months later...
  • 7 months later...
hope this is the appropriate section to post......
just trying to suss the factory under bonnet colour for my gun metal grey R32 GTR....
I know the engine bay is satin black but is that also the same for under the bonnet or should it match the exterior colour of the bonnet (gun metal grey?)
Cheers!
  • 11 months later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
