I've been noticing that there are quite a few gts-4's on the forum, and was just wondering what sort of plans people had for them.
I'm particularly interested in what suspension people have tried, and any upgrades they found suprisingly good or bad.
For myself, I'm aiming it as a traction machine, and so I've got on my list:
Better tyres on 18's (Michi pilots)
coil overs (I was looking at tien, but after some reviews have reconsidered, and am now back at square one on what I would like)
bigger brakes (unsure here too. Have heard mixed reactions to changing to GTR rotors and calipers.)
and maybe some minor power mods. (Already have pod, 3' turbo back, adj cam gears)
Anyone have any stories?
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/
get a 4wd controller, look in the for sale section for them so u can choose between rwd and 4wd
get a spark cut rev limiter (bee *R or a gizmo one)
get a remapped ecu or stand alone
get a pineapple kit for the rear (prevent axle tramp if u have any)
get a castor and camber kit (prevent uneven wear and maximize traction under load so the tyres sit flat and dont sag in)
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2582505
i havent heard much on these, is there any threads or web pages that has more info on these?>
Would love to find out more.
http://www.gizzmoelectronics.com/main.html
Scroll down to: QUICK TEST: "World's Best Gizzmos"
I have one sitting in my room, never got a chance to fit it though.
Will probably kill ceramic wheel turbos :)
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2582789
With the Bee*R spark cut rev limiter, I think you aren't supposed to have a cat in your exhaust system, otherwise it cooks it. Im not 100% sure on this though
same with the gizzmo
or any other ignition cut rev limiter for that matter
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2582801
suspension? -> get this: http://www.skylinesaustralia.com/forums/in...showtopic=87521
sydneykid has the best prices on this stuff your gonna see anywhere...
i have the shocks/springs and camber/castor kit and the handling transforms the car :) plus as AWDMAT said, you get more traction and a softer ride compared to Tein coilovers :(
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2583340
suspension wise... i wreckon gtr suspension with king springs and strut bars is awesome.. .thats what ive got in my gts 4 and it handles like a dream... 235 17inch rims at rears 215 and front... not much traction... power wise... good boost controller, intercooler, exhaust, fuel pump/injectors and u will be rocking it...
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2583425
Why are you running different width tyres?
You will wear out the clutch packs in the 4wd system...
Also, king springs good for handling? lol
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2583427
Any suspension stuff, simply get GT-R stuff. I'm running Bilsteins and Kings lowered springs, with Whiteline GT-R HD rear swaybar.
The best improvement of all - RB25DET. Torque to burn. Next best thing to a GT-R.
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2586143
I'm running a GRID daughterboard on my factory ECU, a GTR fuel pump, HKS2530 on 12PSI (using the wastegate actuator... the Apexi EBC stopped working properly, so just removed it), Tanabe GTR shocks and springs, a switch that I tapped into the fusebox (under steering wheel) to control ATTESA on/off, ARC FMIC, blitz pod, Apexi exhaust, cusco swaybars front and back, GTR wheels front and back (mmmm 7.5kg factory wheels).
It did have an oldschool Apexi AFC and EBC in it, but I've taken them out and am in the process of putting a Jaycar DFA and EBC in it to control things.
Goes nice, altho it does need a bit of a tune as its running at around 12 AFR throughout the rev range.
As for the wheels you can run staggered wheels, as long as the rolling diameter (so that's not just the diameter of the wheels, but the diameter at the contact point on the tyre) is the same on both front and back. so technically you can run 8's on the front and 13's on the back, as long as they're the same rolling diameter. However it's less likely to detect a loss in traction and therefore put power to the front if you run a wider wheel at the back... a small difference shouldn't matter. Conversely if you run a wider wheel at the front it'll detect traction loss more easily... tried it with mine, but the novelty value runs out pretty quick :)
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2587295
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
