I've been noticing that there are quite a few gts-4's on the forum, and was just wondering what sort of plans people had for them.
I'm particularly interested in what suspension people have tried, and any upgrades they found suprisingly good or bad.
For myself, I'm aiming it as a traction machine, and so I've got on my list:
Better tyres on 18's (Michi pilots)
coil overs (I was looking at tien, but after some reviews have reconsidered, and am now back at square one on what I would like)
bigger brakes (unsure here too. Have heard mixed reactions to changing to GTR rotors and calipers.)
and maybe some minor power mods. (Already have pod, 3' turbo back, adj cam gears)
Anyone have any stories?
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/
get a 4wd controller, look in the for sale section for them so u can choose between rwd and 4wd
get a spark cut rev limiter (bee *R or a gizmo one)
get a remapped ecu or stand alone
get a pineapple kit for the rear (prevent axle tramp if u have any)
get a castor and camber kit (prevent uneven wear and maximize traction under load so the tyres sit flat and dont sag in)
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2582505
i havent heard much on these, is there any threads or web pages that has more info on these?>
Would love to find out more.
http://www.gizzmoelectronics.com/main.html
Scroll down to: QUICK TEST: "World's Best Gizzmos"
I have one sitting in my room, never got a chance to fit it though.
Will probably kill ceramic wheel turbos :)
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2582789
With the Bee*R spark cut rev limiter, I think you aren't supposed to have a cat in your exhaust system, otherwise it cooks it. Im not 100% sure on this though
same with the gizzmo
or any other ignition cut rev limiter for that matter
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2582801
suspension? -> get this: http://www.skylinesaustralia.com/forums/in...showtopic=87521
sydneykid has the best prices on this stuff your gonna see anywhere...
i have the shocks/springs and camber/castor kit and the handling transforms the car :) plus as AWDMAT said, you get more traction and a softer ride compared to Tein coilovers :(
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2583340
suspension wise... i wreckon gtr suspension with king springs and strut bars is awesome.. .thats what ive got in my gts 4 and it handles like a dream... 235 17inch rims at rears 215 and front... not much traction... power wise... good boost controller, intercooler, exhaust, fuel pump/injectors and u will be rocking it...
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2583425
Why are you running different width tyres?
You will wear out the clutch packs in the 4wd system...
Also, king springs good for handling? lol
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2583427
Any suspension stuff, simply get GT-R stuff. I'm running Bilsteins and Kings lowered springs, with Whiteline GT-R HD rear swaybar.
The best improvement of all - RB25DET. Torque to burn. Next best thing to a GT-R.
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2586143
I'm running a GRID daughterboard on my factory ECU, a GTR fuel pump, HKS2530 on 12PSI (using the wastegate actuator... the Apexi EBC stopped working properly, so just removed it), Tanabe GTR shocks and springs, a switch that I tapped into the fusebox (under steering wheel) to control ATTESA on/off, ARC FMIC, blitz pod, Apexi exhaust, cusco swaybars front and back, GTR wheels front and back (mmmm 7.5kg factory wheels).
It did have an oldschool Apexi AFC and EBC in it, but I've taken them out and am in the process of putting a Jaycar DFA and EBC in it to control things.
Goes nice, altho it does need a bit of a tune as its running at around 12 AFR throughout the rev range.
As for the wheels you can run staggered wheels, as long as the rolling diameter (so that's not just the diameter of the wheels, but the diameter at the contact point on the tyre) is the same on both front and back. so technically you can run 8's on the front and 13's on the back, as long as they're the same rolling diameter. However it's less likely to detect a loss in traction and therefore put power to the front if you run a wider wheel at the back... a small difference shouldn't matter. Conversely if you run a wider wheel at the front it'll detect traction loss more easily... tried it with mine, but the novelty value runs out pretty quick :)
https://www.sau.com.au/forums/topic/138629-modding-a-gts-4/#findComment-2587295
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
