  • Replies 48
[email protected] 1 1.537 60 foot left the line with a bit too much boost
9.815 still bad traction @15 psi boost
9.573@144mph 20psi boost
9.424@139mph on rev limit
[email protected] 20psi boost rev limit raised to 9000rpm
fixed the traction by dropping the tyre pressure to 9psi
Jas,
Looked again at the datalogs your absolute max boost was 18.8psi - those runs were done at 18psi, not 20psi! :P
Here's a quick vid of your last run the 9.882 @ 146mph + the burnout on the 9.364 run.
SAU_Benaraby.mpg
Edited by Impul_GT-R
Is it still considered a gtst with that engine setup? I mean, wouldn't a "true" gtst fall under the rb20/25 class?
Congrats on the run :laugh:
What would you consider it then? A not "true" gtst hahaha
Is it still a Skyline ... yes
Is it still powered by a nissan 6cyl ... yes
Did it beat the current GTST time thats also RB30/26 ... yes
Is it currently the fastest GTST ... you guessed it YES hahaha
Jas awesome awesome work, that record has stood for years huge achievement beating it well done
You running methanol yet?
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
