Need some advice
my mate bought a R32 GTR about 3 months ago. got it serviced, some minor things fixed. timing belt was enspected, no need to replace
its got a big exhaust, running about 13psi with stock engine as far as he knows.
few weeks ago he was driving home sedately and the engine just died.
turns out timing belt tensioner failed. no compression. Needs rebuild. but has not been opened up yet.
He's been told by a big name auto place that it will be between 5k and 12k to fix depending on the damage.
what would you people suggest...
considering the bad stories you sometimes hear about crap rebuilders do you's think its the right option? GTRgeoff says he doesnt trust any place and only rebuilds himself.. hehe
instead should he buy a new engine? 12k is remarkably close to a new crate engine.. ??? (15k for N1 right)
or is it just overkill? what about an engine already rebuilt by a reputable workship?
what sort of guarantee would you expect from a shop after having an engine rebuilt or a replacement rebuilt motor bought?
and what do they generally go for?
also, it still has the standard turbos.. should they be replaced incase they fail soon and destroy the engine?
I have read the "report that engine failure" thread and its scary expensive stuff.. i dont want him to spend thousands and have it fail again in 6 months time..
Edited by NAITR
https://www.sau.com.au/forums/topic/139299-what-to-do-r32-gtr-engine-failure/
What state are you in?
How long do you intend on keeping the car?
If its a short peroid of time, get a second hand RB26 in and sell the car.
If not, no doubt could recommend some good places to get a reliable rebuild done at a reasonable price.
My engine didnt die but im currently rebuiding it. It is also an RB26. If your in Brisbane i have full faith in JHH Engineering. They doing the machine work for me and i will be building it. I also was faced with the question of re-using the standard ceramic turbos or replacing with steel wheeled items. i chose the safer option of replacing. However i am going to rebuild the ones i have to higher spec thru sliding performance. For $1200 its a pretty good deal. By the way a rebore is $220 forged pistons are about $1000-1400 depending on what you choose. However i am doing all the R&R labour myself so it would be much more expensive to do if your not a mechanic. You'll also want to check the crank as it has possibly spun a bearing or done some sort of damage in that department. A new set of bearings isnt too expensive. Anyway as long as his engine isnt totally destroyed i think he should just rebuild what he has would always work out cheaper...
we are in Adelaide
Dont know.. he's still deciding whether to keep it or sell it when its back on the road..
it would be sensible imo to get it done properly and then keep it long term.. that way your not wasting money on repairing a car for someone else..
but not sure my mate can really afford to do what needs to be done.. or if he's just too pissed off with it to keep it.
Edited by NAITR
If you plan to simply fix and sell, then get a replacement from the wreckers and install it. Otherwise, rebuild the dead one - and ask to talk to previous customers of the engine builder if you have any concerns.
Open it up first and see whats broken/failed
I know of one up here that failed, but if it needed to, COULD be back together with a light hone and new bearings etc which would end up being a lot cheaper than 12k
Same thing happened to my first GTR, engine blew badly, wasnt driving sedately!! I replaced with a R33 engine and sold my blown one, whole thing ended up costing me about $3k all up, pretty good for a nice newer engine and it drove soooo much better after that.
  • 1 month later...
$3,000 for a R33 RB26 dropped in? Thats a steal.
no, he means he sold his own broken engine (let's say for $2K) had new R33 GTR engine bought and installed (let's say cost $5K) the total 'cost' to him was $3K ($5K-$2K=$3K).
  • 3 months later...
What are the kms now? At import you have it at 76,000kms. Was it a rough drive from fresh import?
If thats your car in the link in your sig I'd say you will not find another RB26 in the same condition on the outside. Its not a VSpec is it? I say rebuild yours as you could probably get away with using a lot of the parts on your current engine as well.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
