Just got home from a long run through the night. Silly bastared left the keys in plain sight :laugh:
The thing is meant to be running std boost....but the gauge reads 1.5bar !!!! Is that std boost for an EVO? No wonder they go do bloody well, thats a lot of bosot for a std car
.... PS, i did go for a drive, but didnt take it without his permission. Im no low mongrel. But that is the boost it runs. And it is so very nice and tight to drive....seats, gearbox, clutch, all feels great
  • Replies 192
VERY nice james... Advan RS's are THE rims to get for an EVO 8 or 9.
So tempting... i was going to buy a GTR next year but decided i would save a little more and wait for the EVO X to come out... ive always loved the EVOs... I want one now.
Just got home from a long run through the night. Silly bastared left the keys in plain sight :)
Standard boost is around 1.1/1.2 bar
Kam - I stopped at the BP in Albury at about 7am, figured you'd still be snoozing
Matt - Yep, will be getting my backside trackside next year - and of course at DECA
Greg - yeah, he may not be as hard-corey assassin styles as THE Golgo, but I'll have the plates on there lickety split. Must maintain the illusion that I'm cool :)
Mav - not only a working heater, but aircon too. Woo!
Akeenan - OK, totally different machine to the R. Feels 'zippy' rather than powerful. Is definitely quick, but doesn't have that endless power sense you get in the Skyline. However, it basically has it's power whenever you want it, and certainly feels much more nimble and chuckable. Plus - it's practical. 4-doors, big boot, easy in traffic... In the garage next to the R32, it really makes the Skyline look like a low slung sports car. Is longer than the R32 - and in reality, quite big. Plenty of room for me to sit in the back, and I'm no Leewah.
Is more a 'practical' GT-R alternative, rather than a competitor. Is still fast and fun - but in a different way. GT-R is still the king of the track, but for a daily driver... Evo FTW.
* will take some better pix on the weekend
Re: Boost.
I'll have to check for vacuum line mods, as there is no EBC and it's on the stock ECU. Has DEFI boost guage (sweeeet) that reads 1.5bar with the hammer down. Due to the different turbo setup on the MR, is factory boost different? Will have to do some learning...
Re: Boost.
Are you sure the turbo is different on the MR?
I was under the impression the MR is just the lightweight RS version, with all the goodies from the GSR..?
If they've bypassed the stock boost solenoid, it would be running off the actuator, which might be 1.5bar
You should check it out first, but the stock 560cc injectors should be able to handle 1.5bar fine
I know the turbo outlet on the MR is different to the GSR. It also gets a different exhaust, aluminium roof, oil cooler, swanky suede seats etc
This from Mitsu press release:
The well-proven 2-liter in-line 4-cylinder 16-valve DOHC intercooler-turbocharged 4G63 engine has undergone detail improvements. The power unit retains Lancer Evolution's trademark flat torque band that kicks in from low engine speeds but now generates gutsier torque in the mid- to high-rev band.
The turbocharger uses a larger turbine nozzle with matching cam profile to deliver higher output at mid- to high engine speeds.
The turbocharger waste gate now uses two solenoids. This optimizes boost pressure control to give more stable torque in the low to mid-range and helps the powerplant to generate class-topping torque of 40.8kg-m (400N-m) at 3,500 rpm.
Durability is improved through shape optimization and reinforcement of the cooling water channels, uprating from a 3-ply to 5-ply head gasket and the use of magnetic ion-coated piston rings.
Engine response is improved with the use of lighter silent shafts. Cooling performance is improved with the use of a larger oil cooler that features two extra rows.
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM E8)
TD05HRA-16G6-9.8T (RS/RS2)
Nozzle Area (cm2) = 9.8
Turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
RS/Rs2=Titanium alloy.
Compressor = Aluminium, 68mm wide
Evolution MR aka "8.5"
GSR = TD05HR-16G6-10.5T or TD05HRA-16G6-10.5T (Ti Alloy option)
RS = 6MT:TD05HRA-16G6-10.5T or 5MT:TD05HRA-16G6-9.8T
Nozzle Area (cm2) = 10.5 or 9.8(RS-5speed)
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels (see first pic). As the engine exhausts in pulses.. its supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. Anticlockwise (hence the R in the turbo name). The Titanium Alumnide alloy used in the RS/RS2 and some GSRS (factory option) has less inertia and thus spins up around 500 rpm sooner. These Titanium turbos can be indentified by the A in their name.
James kisses boys and drives a Lancer.
Looks pretty sweet, We will see just how good it looks on the track with tyre smoke ripping off the guards and you driving it like you wanna break it!
Really needs the rims.
You suck
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
