Just got home from a long run through the night. Silly bastared left the keys in plain sight :laugh:
The thing is meant to be running std boost....but the gauge reads 1.5bar !!!! Is that std boost for an EVO? No wonder they go do bloody well, thats a lot of bosot for a std car
.... PS, i did go for a drive, but didnt take it without his permission. Im no low mongrel. But that is the boost it runs. And it is so very nice and tight to drive....seats, gearbox, clutch, all feels great
  • Replies 192
VERY nice james... Advan RS's are THE rims to get for an EVO 8 or 9.
So tempting... i was going to buy a GTR next year but decided i would save a little more and wait for the EVO X to come out... ive always loved the EVOs... I want one now.
Just got home from a long run through the night. Silly bastared left the keys in plain sight :)
Standard boost is around 1.1/1.2 bar
Kam - I stopped at the BP in Albury at about 7am, figured you'd still be snoozing
Matt - Yep, will be getting my backside trackside next year - and of course at DECA
Greg - yeah, he may not be as hard-corey assassin styles as THE Golgo, but I'll have the plates on there lickety split. Must maintain the illusion that I'm cool :)
Mav - not only a working heater, but aircon too. Woo!
Akeenan - OK, totally different machine to the R. Feels 'zippy' rather than powerful. Is definitely quick, but doesn't have that endless power sense you get in the Skyline. However, it basically has it's power whenever you want it, and certainly feels much more nimble and chuckable. Plus - it's practical. 4-doors, big boot, easy in traffic... In the garage next to the R32, it really makes the Skyline look like a low slung sports car. Is longer than the R32 - and in reality, quite big. Plenty of room for me to sit in the back, and I'm no Leewah.
Is more a 'practical' GT-R alternative, rather than a competitor. Is still fast and fun - but in a different way. GT-R is still the king of the track, but for a daily driver... Evo FTW.
* will take some better pix on the weekend
Re: Boost.
I'll have to check for vacuum line mods, as there is no EBC and it's on the stock ECU. Has DEFI boost guage (sweeeet) that reads 1.5bar with the hammer down. Due to the different turbo setup on the MR, is factory boost different? Will have to do some learning...
Re: Boost.
Are you sure the turbo is different on the MR?
I was under the impression the MR is just the lightweight RS version, with all the goodies from the GSR..?
If they've bypassed the stock boost solenoid, it would be running off the actuator, which might be 1.5bar
You should check it out first, but the stock 560cc injectors should be able to handle 1.5bar fine
I know the turbo outlet on the MR is different to the GSR. It also gets a different exhaust, aluminium roof, oil cooler, swanky suede seats etc
This from Mitsu press release:
The well-proven 2-liter in-line 4-cylinder 16-valve DOHC intercooler-turbocharged 4G63 engine has undergone detail improvements. The power unit retains Lancer Evolution's trademark flat torque band that kicks in from low engine speeds but now generates gutsier torque in the mid- to high-rev band.
The turbocharger uses a larger turbine nozzle with matching cam profile to deliver higher output at mid- to high engine speeds.
The turbocharger waste gate now uses two solenoids. This optimizes boost pressure control to give more stable torque in the low to mid-range and helps the powerplant to generate class-topping torque of 40.8kg-m (400N-m) at 3,500 rpm.
Durability is improved through shape optimization and reinforcement of the cooling water channels, uprating from a 3-ply to 5-ply head gasket and the use of magnetic ion-coated piston rings.
Engine response is improved with the use of lighter silent shafts. Cooling performance is improved with the use of a larger oil cooler that features two extra rows.
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM E8)
TD05HRA-16G6-9.8T (RS/RS2)
Nozzle Area (cm2) = 9.8
Turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
RS/Rs2=Titanium alloy.
Compressor = Aluminium, 68mm wide
Evolution MR aka "8.5"
GSR = TD05HR-16G6-10.5T or TD05HRA-16G6-10.5T (Ti Alloy option)
RS = 6MT:TD05HRA-16G6-10.5T or 5MT:TD05HRA-16G6-9.8T
Nozzle Area (cm2) = 10.5 or 9.8(RS-5speed)
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels (see first pic). As the engine exhausts in pulses.. its supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. Anticlockwise (hence the R in the turbo name). The Titanium Alumnide alloy used in the RS/RS2 and some GSRS (factory option) has less inertia and thus spins up around 500 rpm sooner. These Titanium turbos can be indentified by the A in their name.
James kisses boys and drives a Lancer.
Looks pretty sweet, We will see just how good it looks on the track with tyre smoke ripping off the guards and you driving it like you wanna break it!
Really needs the rims.
You suck
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
