LOL! Thanks people! Yeah I normally keep it quiet, especially at my age!
Not sure about tonight. Was just going to get some food with Nic.
Mav, sorry did get your message along with several others so didnt get chance to reply as I have been driving all morning. :)
https://www.sau.com.au/forums/topic/139606-happy-bday-saff/#findComment-2602485
Had an excellent day and thanks for the wishes everyone. Have spent the afternoon washing the Evo and taking some pics with JW and his which I am sure will be posted soon. I am a bit of hack at washing the car so hopefully pics are in a good light.
Am open to suggestions if anyone is around tonight. Will grab some food now and open some wine but if anyone does fancy some drinks down this way, even Taco Bills in South Melb, I am up for it :laugh:
https://www.sau.com.au/forums/topic/139606-happy-bday-saff/#findComment-2603044
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
