  • Replies 208
well i got a mate thats just gettin into the photogragphy thing an if we want some one to do a shoot for scs he said he would b keen if we hook him entry an a little cash (as his gear is not cheap by any means) an i could get him out all weekend for the cruz an everything maybe for the ppl entering 10$ each an u get a cd full of phots
I'd love to come along!!
Any objections to a series 2 Stagea coming along?
It looks stock but it isn't (3" turbo-back exhaust, GT30 turbo, boost controller set to 11psi, safc, shift kit). 170rwkw (about ~150awkw). :D
mt lofty would be cool. Are we talking about the botanic gardens carpark?
might be difficult to get any scenery in the background with that carpark...
Wouldn't bother me though - I'd be happy with a nice pic of my car and some pics of skylines "lined" up together.
The whole photoshoot thing is a great idea btw!! :(
EDIT: Oops, just realised I may not be able to come on the scs saturday. damn. Oh well, I'll be there if at all possible, otherwise I'll look forward to seeing the pics...
Edited by pixel8r
I cant believe you still have those pics. That day was one not to forget.......
Looks good, how many cars could it fit? May have to do a double layer shot if not big enough.
Of course the skyline wagons can come....
Edited by gts33t
What about a DR30 to finish that line of skylines off???? Have to let me know what date your thinking about though, cause i've got a few things that i need done to her first, nothing major though!!!
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
