Yeah something I should have checked but oh well lol
I have a different front cover on mine to standard to block the anti surge slots off. Think this loses alot of flow when the standard anti surge holes are in there. It's not a big enough Turbo to warrant surge slots IMO and provides more cons then pros
Its much nicer to drive with my front cover on, fixed a few small issues. But it's not a great "fix" at the moment. Was hoping HKS would give me a Pro S front housing to try as I think this will improve it
But anyway, it's good enough for now
hmmmm, interesting. Though I've never done much reading on the 28's etc with anti surge etc to know pros and cons, but it's a bit of a strange one it would be better with it blocked :O
I had the GT3076 or the "GT3037"
0.6 Surge slotted comp cover
0.63 rear housing
Put the 0.82 rear housing on when I switched to the RB30.
I found the surge slotting was ok, especially when I had the BOV removed for a short period of time, and when in higher boost the factory BOV couldn't keep up and it created reversion.
Would have loved to try a non surge slotted cover, but I have heard stories of the surge slotting allowing more air in further down the blades, allowing the turbo to spool faster. Wouldn't have a clue if it does or not though, its something you'd have to try yourself.
Callan, what is your lag like?
On the RB25 I had 18psi by 3400 in third
On the RB30 I had 18psi by 3000 in third, maybe earlier. Hard to tell it moved that quick.
Surge holes like this?
The port shrouding on the Pro S housing is more typical on a turbo of this size. By the time the air has reached the rear of the surge slots there is some pressure there. And the other end of the holes are on the suction side of the turbo. Long physics lesson short, high pressure always wants to go to a lower pressure section. Pressure difference = flow. So therefore there will always be flow lost that would normally go into the engine that is now being recycled back through the blades
This is how I understand it anyway, what I know about physics makes me think I'm right and Stao from hypergear originally told me it would be the anti surge slots that are the issue. On a T04Z there is a benifit as such a large air flow might result in some surging. But a small GT30 series doesn't flow enough for me to think anti surge slots necessary.
This is what ive done
But as there is no actual seal in the snout of the Turbo to the housing, there is more then likely a leak between the two, again this will mean a slight loss in flow
This is how I See it anyway, hypergear will make me a new housing but want the whole turbo. Seen as it is my daily, I need the car so this isn't really possible right now
yeah thats the whole idea about the anti surge housings.
but i wouldnt think it would make that much of a difference.
its only if there is too much pressure so its squeezed out these holes.
i thought there was 2 blades on these turbos and the holes go ruffly to where the 2nd blades are.
maybe not and they are on the pressure side but then wouldnt it just be working twice as hard ??
air would be recirculating no ?
My 180 will be in Mky soon. It goes brum.
nice ride. gl wit it.
:lol: jokes this isnt boost.
Callan, whole heartedly agree with what you have to say about anti-surge. it is a good talking point really. ;)
I've heard about this sil80
Word is it's packin' heat! And getting tuned by mackay's finest?
you should be more worried about the 1 up your way.:P
i've heard a few things about the 1 your talking about, apparantly the owners mad c&*t :wave:
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
