$17/hr and on site.... LMFAO daylight robbery, enjoy workin for peanuts haha
it is good to get a trade but u gotta be willing to take a pay cut...
thiess is a "bigger mining company" so im sure they can pay a little more then 17 bucks n hour
Wher from mate? My boss is the manager off Opposite Lock accessories and i sell used cars here. I should be able to help you out.
Quote was from ARB for the lockers coz that the brand i want.. Snorkel was TJM. Dunno bout the lockers fair bit of coin when iam already spendin a bit on the GTR
Ah true, what sort of ute is it for? I can try get you some prices from here if you want
I'm on $40ph now, in town, airconned office, I'm the boss, and I can come and go when I please, so its probably not worth it. I'll just have another look next year and see if I still want a change in career.
Thanks for all the advice though, appreciate it
Edited by The Mafia
i remember when i was on $60/hr :'( pitty i was working with a bunch of F.U.C.K..W.I.T.S
still got to put a fair bit of that coin away.... seriously though mature age appt. i thought was 4th yr wage and well unless ur doin hairdressing im pretty sure 17/hr aint right
worth a look into it
Will do, definitely not good form from someone like Thiess.
Its not like I am some young di.ckhead with no clue, absolutely no life experience, getting drunk every night of the week.
I'm an old di.ckhead.
Off topic from money-
I was speaking to a guy in the states on the topic of gearbox and diff oils and he seemed to think Redline oils were bad and to stay away from them and that Amsoil oils are much much better.
thoughts? Everyone i've ever spoken to that runs Redline oils reps it well so i find this hard to believe.
I'm having a tuff choice on a braking package for my 180sx. I can't run my existing AP Racing Brake package i had on my GTR as it is huge and bit too heavy and won't fit behind my wheels. I have decided to sell them to Jordan for his GTR which will look pretty deadly.
At the moment i will be running R33 GTR 2 piston Brembo's on the rear which is cool as the car will probably weigh anything from 1000-1150kg. So big brakes are over kill.
just get 33gtr fronts with project mu rotors and some decent pads, a mate has that setup on his 180 and it is great for circuit. make sure you use a bm50.
mafia- i see that as great money, when i did my first apprenticeship i was on $5.50/hr. being mature age you should also be able to do it in 2.5yrs.
I Run Redline Oil in the R32 Drag Car gearbox as per recommended by everyone one I have ever talked to. Seems to be pretty good stuff a lil expensive but hey its a $11k gearbox so its gotta have the best.
Yeah my old man spoke to John from UAS and he said most time attack Silvia's just run stock brembo system but the car has to be light. I am running a Tilton pedal box with dual brake reservoirs so will have plenty of grunt.
Thanks for that benny, i guess they are both just as good as eachother.
Looks like I am going to be running Brembo Brakes off a Nascar just waiting for old mate in the USA to get back to about shipping. They are the ducks nuts One piece monoblock calipers with titanium pistons, Big Piston 4 pot fronts 330mm rotors front and Small Piston 4 Pot Rears 300mm Rotors. Surprisingly cheap just have to get custom dog bones and lightweight rotors made, no biggie. Can't wait to test these out gonna put me through the windscreen.
Sheep....? It's proven to work.... to a point.
We tested it in a S15 running a Rb25 cogswapper, was great! until the shit got hot and basically became glue... and when I mean glue, it wouldnt let the shifter move from 3rd cog...
Swapped it out (went in because I have it in the GTR's PPG box) and had no more problems even in same form of flogging.
I run Redline Lightweight Shockproof in my gearbox and its better then ever. All good that stuff :thumbsup:
as posted Above.
Coincidentally, I gave PPG a call today and had a chat about oil to use with my gearset. And will be moving to Martini 75-140 as soon as I am ready to swap the redline oil out.
as posted Above.
Did Redline Exist when your Car was last on the road :P
I get your point, its been a bit hit and miss lately. Some people complaining about it shooting out the breathers and after x amount of km it becomes worse then its ever been with any other oil
Mine is better off with it. But not for everyone. I cant say a bad word about them for that reason :)
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
