sean, how have you not seen them, your at more events then i am haha. all of them very nice though. and my mate in brissy said the was a powercruise in august i think. was thinking bout heading down if anyone else was. tickets are cheaper now also then in a couple months time. so when is everyones car going to be back on the road and drivable again. im getting my front calipers overhauled and new lines, was having trouble bleeding them, got bored of that very quickly, so hopefully be all good in a week or so.
powerplay is in may (1 day event) powercruise is 5-8 september.
some of the townsville guys maybe heading down with a 34gtr with -5's and s15 with sr20ve
and victoria is already looking heaps better than NQ :D they have proper roads & shIt
I'm the First Australian owner of my car :)
Bought it stock as a rock, Appeared in a magazine but (in an Adrenaline imports ad :P ) Back when it had 32 GTR mags and the Series 1 front
Damn I've spent to much money on this thing :(
You guys have roads up there?
I drive it every day to work - its completely f**ked.
I've seen some holes that were over 1 foot deep. More than enough to destroy my little corolla :(
Yeah it's awful, they just finished doing a heap of roadworks there too haha..
I usually go that route to get from my yard to Autocorner, need a 4X4 to navigate to the other side if you value your suspension/wheels/body parts haha..
I'm annoyed - only 3 shit quality R34 GTRs went up for auction this week.
The f**ked thing is with this North Korean dickhead, it could cause massive issues with importing a car.
Hope he gets f**ked up bigtime, him and his entire f**ked up family. They are all the same.
http://www.news.com.au/world-news/starved-of-food-starved-of-the-truth-how-kim-jong-un-suppresses-his-people/story-fndir2ev-1226616134393
Did u look into that link I posted on that r34 ?
Yep totally agree, he's crazy. American's will f*ck them up hard though i think, if it does end up in nuclear war..
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
