Haha yeah, I read lots of stuff about the Greddy radiators not taking the stock shroud so I was happy when this one did. Everything fitted up perfect, was great.
Coolant temps stick around 83 degrees while I'm driving now, definently keeping the thing cool
Just need some foam for around the top and in a few spots to keep the airflow through the radiator, but its minor shit really
yeah ive never had a problem with shrouds refitting.. I just broke mine lol. but that's good it all fits sweet. its a pain when it doesn't.
get some n1 slots. although depends bow big intercooler is, that will give some extra air through it
If anyone is interested I have a few things for sale
RB25DET head, complete internally with rocker covers and CAS bracket. Think it has VCT solenoid, if not I have a spare. Has leaking valve stem seal or needs seats cut so would suit a rebuild. Other then that it's in good condition
2 silicon reducers - 3" - 4" and 3" - 2.5"
Stock RB25DET exhaust manifold with heat shield
  • 1 month later...
  • 4 weeks later...
Just down the road at Freshwater Pt near Armstrongs Beach, just inherited a 4 door from my mate who passed away. Joined this forum cos i know f all about skylines but after driving the thing home from Bowen i can understand why you all love em. Will be slowly restoring it to its former glory as time and funds permit
  • Like 1
welcome alan, its always a slow process mate, haha. but you will get there. ive had my gtr near on ten years now, motor was first thing to be done, and just last year was all the cosmetics. slowly tickering with things. most people will be able to help on this forum if you have any questions.
  • Like 1
Thanks Jordan, first thing im doing is the body and then brakes/suspension. The performance in standard form is good enough for now but i have a feeling that once the body work and suspension are sorted i'll want some more ponies. I do have a few questions; Is there anyone you can recommend to supply and fit a body kit (doesnt seem to be many options for 4 doors) here in Mackay?? Are there any workshops that specialise in Skylines in Mackay?? And where would i start looking for things like chrome door trims (got one missing) and new headlights, grill badge etc, are there any wreckers who specialise in nissans??
if your on Facebook (or there may even be a website), search for Proximity Motorsport. Leon has been messing around with Skylines etc for years now.
As for the parts for your car, if your chasing them new, I can get some part numbers and see how much for genuine new replacements. You won't have too much luck with wreckers in Mackay, so you'll either have to go through one in Brisbane or further, or buy new.
If you want me to have a look, I just need your VIN number (the 6U900 or whatever number it is isn't important) and a good description and I can search for you.
  • Like 1
Thanks Cal, i have checked out proximity on face book, was hoping to hear some positive reports before i spend my hard earned so cheers for that, i'll tell him you sent me. I'll have a good think about the genuine parts i would like to get and let you know. Do you work at Nissan? Can't tell you how much i appreciate your offer to help, thanks again.
I don't work at Nissan, but have access to their parts program and know the best place to get stuff from. When you have ordered as many genuine parts as me you soon work out the best way to get it lol, and it sure as hell isn't through Nissan Mackay
  • Like 1
  • 4 weeks later...
  • 1 year later...
I think Mackay not having much money is half of it. Tune the car, make them happy - then to find out they never had the money to pay in the first place "I'll pay you in a few weeks".
Plus, facebook is bringing the idiots out. Everyone is an expert, no one has a clue..
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
