Hey guys .
Some of you guys may know me although i am generally more active on SILWA . I do not get to cruise much as i work nightshift but this is all about to change. For over a year now i have been fabricating Custom Stainless Exhausts and Cooler piping , mainly on the weekends but also during the week. Basically i got soo busy that the stress of working my own business during the day and then working nightshift and working weekends has destroyed my marriage. I have now decided to make my business a full time business.
My business name is KERMIT ENGINEERING ( to be registered shortly) and I am looking for declarations of interest of what i have on offer.
My main Product will be Exhaust systems. I will be offering Custom Stainless Mandrel bent Catback Exhausts for $600 to $650 ( customer to provide muffler ). These exhausts are built to sit as high as possible and are installed with custom Stainless hangers. All welding is TIG . $650 is for a 3" system , a 3.5" system may increase the price a little.
I will also be offering dump pipe back systems also but will quote these on a one by one basis. Obviously a GTR will be more than a GTST because of the twin front pipe layout. Custom dumps are also in the pipeline , first will be custom widemouth dumps and later on will be split dumps .
I also do Cooler piping . So far i have done S13's ( Ca , SR and Rb20 ) and will be offering this when i have the workshop running.
All my work is Custom . I am also happy to modify ' China ' or Xforce products as these never seem to fit properly .
Thank you for your time.
Kermit
So what do you think? :)
https://www.sau.com.au/forums/topic/141182-custom-stainless-exhausts/
  • Replies 353
Posted Images
What about manifolds?
and maybe cat delete pipes? :)
You might have a hard time finding your niche, if your workmanship is up there (which it sounds like it is) you'll get the performance crowds attention and you'll be able to price it accordingly. On the other hand theres probably more ricer types wanting cheap exhausts for there shitboxes.
If you ever need an RB20 test mule I'd be more than happy to help out :rofl:
Best of luck with your new business
do i have a job for you!
i need some custom cooler piping made up to suit my forward facing plenum'ed RB25.
i am also after a twin exhaust for my 33 gts-t..
basically i have a 3.5"system on the car already, and i would like for it to split into a twin 2.25, or twin 2.5" system just behind the dif, and run one to either side of the rear bar, and exit with a 3" chrome tip on either side.
and preferably have the muffler(s) hidden from view.
it doesn't seem like that hard a job to do, just most exhaust places will only offer me the typical 3/3.5" with a cannon system, whereas i want something different.
let me know if you are up to it. :whistling:
sounds good mate. custom twin is no problem but i would have to check the clearance on the drivers side of the fuel tank to exit out of either side of the rear bar. As soon as i have premises sorted i will let you know but this sounds awesome. at the moment as i am still at home i can only do basic catbacks but i am trying to find a place with a workshop . once i have a place with its own workshop i can do this for you no problem. i am also in talks with a motorsports business about renting out part of their workshop. if i can work from home it takes the pressure off until its sorted out.
am definately up for it
kermit
let me know if you are up to it. :D
gimme a look sometime Topaz. sounds simple enough. my GTR is for sale , i always wanted to do the same on that car but spent all my time modding the wifes sil instead.......then she wrote it off
kermit
intake plenums are a possibility. if this business is successful then i wil purchase an ac/dc Tig so that i can make these as well, although its not quite that simple . im a fabricator not an engineer.
Intake piping for a GTR with a D-Jetro?.
I need to those AFM's out of there....
kermit
Maybe take a look in your GTR and see if its doable. I will need to get some silicon connectors and clamps and some APEXi pods as well, so I guess the sizing will be guessed unless you have gap sizes with the pods available, yes?
Do you have a bricks and mortar yet or are you still to move into a shop?
Wil you do things like clamps and silicon connectors?
cheers
Tom
kermit
i've been under the car all weekend trying to remove my driveshaft, and there seems to be a fair bit of clearance for a 2.5" pipe once you get past the rear subframe. (thats where i want it split anyway)
the only issue i see is the tow hook..
Ok, Here a few pics of The 2.5" Stainless Cat Back Exhuast Sytem Made for a Silvia WA Member - DKC for his S13 Sr20de.
Was made From 2.5" Stainless and 1 x 90" Stainless bend (Not polished), Also DKC Supplied a Muffler to Suit it.
Will Try next time to get some better picture for you, But all pictures should work.
Some Pictures Of the "Drift" Angle you can get, also the quality of work, and I also just like the last pic :D
*Note the close up picture of the Weld, Was cleaned up afterwoods, this was pretty much straight after it was done.
Cheers
Edited by GTRboy
exhaust includes fitting of a cat ( stock or highflow , supplied by car owner) and same with the resonator. All of the jobs i have done so far have only required a single muffler . The sound from my GTR is blood curdling and i have so far had no problem from the police. although there was that one time where they couldnt keep up............
kermit
rough idea to fabricate piping for r34 intercooler?
does the exhaust includew cat and resinator? or just pipe
cooler piping for a r34 ? rough quote of 700 inc silicon and clamps.
i have yet to do a skyline and would provide a more accurate quote once i have the car in pieces as i can work out what bends i need etc.
will provide pics shortly of cooler piping that i have done
kermit
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
