  • Replies 353
Posted Images
8 pages long now... I think the answer to the question "custom stainless exhausts, interest?" is a massive "YES!!!"... how about we keep on topic and in this thread and maybe make this a sticky in the for sale section?
just my 2c as this thread will probably continue... which a testiment to Marks work... good luck with the new workshop mate :thumbsup:
i was muckin around the other day with my mate and disconected my cannon and god damn did my car sound nice, had a really nice roar to it i was thinkin is there anyway possible my cannon could be cut off and mayb u could make up a bit of stainless 3 pipe and weld it on lol ? sounds stupid i know but i mean when the cannon was disconected it actually sounded like a performance car
sam
hey sammie
that would be no problem at all , just let me know when you want it done.
kermit
hey this sounds like an idea
accept my muffler is welded to my exhaust piping, the next set of flanges are were it joins to the cat *sigh*
so my question is can you make a cut after the muffler and put some flanges on to and also have a piece of pipe put in there to eliminate the muffler, i want to be able to interchange between strait through pipe and muffler......if that makes sense lol
regards
the other Sam :)
regards
the other Sam
copy !!!!!!!!!!!!!!!!! jst kiddin hha would be goodtho if he can make somthign up like that.
regards
the cooler sam
Currently mark aka kermit is working on my rb20 180 here some pics of the cooler piping in the process of been made...
also like to note that mark currently is having pc issues which are been fixed should be getting back online soon
here is a link to some pics of what the work been done *note all taking with a camera phone*
http://mrlags.blogspot.com/
regards
the other Sam
regards
the cooler sam
hey guys ,
tis easy peasy lemon squeasy ,
just gimme a shout
kermit
just a question will the weld marks on the exhaust rust out after a while?
no the welds on the exhaust will not rust out . eventually they will oxidise ( easily cleaned off surface )a little ( am talking many years ) but they will never rust. thats why people use stainless instead of mild steel. i always source good quality stainless materials and filler rod , not low quality china spec stainless steel .
i am always disgusted when i see stainless products which are rusting . thats why i hate china products.
kermit
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
