  • Replies 80
Its drivable at last, so I will be there also. :)
PS. How come this and other fixed events are not listed in the SAU Forum Calendar??
Ah...love it.
Haven't been rostered on a sunday for about a month....Get my roster for next week....BAM sunday for you dezz!
If the money wasn't so good i'd cancel the shift and still come
as above, what time will it go to?
I would have loved to enter, but didnt realise this was on the only day we organise a Stagea cruise lol. But i think our cruise is going to head on over to check out the show and shine.
Thanks Bec, yes I know its there, but not here:- SAU Calendar
just wondering why its not used as easier to access??
i know it states that cars must be entered around 10am....i might not be able to get their til around 11 is that ok or would that be too late to put my car in ??
also with the whole show and shine thing, as im not a member do i have to fill in any papers to put on my windscreen as no one can vote for me anyway
Only SAU VIC Members will be able to participate in having their car entered into the Show N Shine display.
Only members can be IN the show n shine...everyone else is there to look...
My understanding was that only members can park on the grass area set aside for the show n shine...everyone else parks wherever they can find it...but don't quote me on that one
That is correct - only cars who are entering the Show N Shine will be permitted to park at Birrarung Mar.
Anyone coming along to have a look will need to find parking somewhere and walk in.
You will be able to join as a member on the day, but to make things quicker, I would fill in a membership form and bring it along with you, as well, with correct money.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
