It will vary quite abit (im speaking 1/4 mile times) depending on:
* Tyres
* Track
* Mods
* Driver
* Track Temperature
* Car Tuning
* etc, etc, etc, etc.
What im basically saying is that just coz Joe Blow has this n that done to his car doesn't mean its capable of running a 13.xx or a 12.xx
dremen,
I ran a 13.4 and a bunch of 13.5's with:
Std ecu, std intercooler, std turbo 10psi.
Full exhaust, light flywheel and standard airbox with a replacement K&N element.
I ran a 13.8 without the light flywheel.
then again your mate is a guru so I must have dreamt it all (even the time slips I have posted).
low 14 is very possible with a near stock R33 (cat back/filter, standard boost).
With front mount/exhaust and boost with the right launch, decent set of rubber it will be good for a high 13 easily.
I ran a 14.2 with cat back/filter and standard everything else including boost.
13.981s at Calder Park on a cool night. Most other R33 were running mid-14s that night. I think i can get closer to a mid-13 with my setup.. see "13.4s time for stockish R33" in Forced Induction" section for all talk about this sort of thing.
Practice and grip is the key. BOV does jack all.
DREMEN: i use stock suspension and i think lots of ppl think its the best :D
-well if u use aftermarket e.g Bilstein shockies+springs, u better get rear camber adjust if u lower ur car(skyline's dont like lowering,wrong camber will cause excessive camber hence wheelspin)
-pineapples to reduce axle tramp
-anti lift kit perhaps?
(the stuff i said above was quoted 1200-1300 for me)
p.s i seen a few ppl using "drift" suspension and getting terrible times
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
