Looking at upgrading my standard exhaust manifold. Not even going to bother with the ebay crap. Heard bad things and pretty dam cheap for quality id say. Pay for what you get!
Unique autosports offers one. Anyone have one? Would like to hear feedback on their quality and durability.
  • Replies 93
do a tig welding course then borrow a tig and make it yourself then get it ceramic coated. if you do want to buy one, get one where the "pipes" from each cylinder to the merging point (where they all meet) are the same length.
For what its worth, my Greddy manifold is a 6-3-1 style manifold, Not equal length 6-1 and it works a treat. Though the airflow is still uniform and the collectors nicely done. I dont think the equal length is the end all be all ...is it ?
IMO it isnt.
My GTS-R one wasnt equal length either.
Was good enough for Nismo, was good enough for me :P
Other guys - please dont just call something "garbage" without an iota of proof. Refer to the forum rules.
Posts removed
I'd like to see a direct comparison between the manifold in question, a factory manifold and a "name brand" AM log style. I reckon the performance difference between the 3 would be bugger all.
Edited by Lazy-Bastard
The basic theory behind manifold and exhaust pipe length tuning is based on organ pipe theory. A tuned length exhaust is literally that - a length at which the pipe has a natural frequency of resonance which matches the resonance of the engine at a particular engine speed.
Longer tube lengths pull the torque down to a lower R.P.M. range. Shorter tubes move the power band up into a higher R.P.M. range. The amount of straight in the collector extension can move the engines torque up or down in the R.P.M. range. Longer extension length will pull the torque down into the midrange.
Really most people design the intake, cams and header to be optimal at a certain RPM range as the standing wave can only be created at a single RPM. Good for dyno shootouts...not street driving.
IMO for street cars get a well constructed deisgn...not lips etc...nice joins at the collector and a design that suits your needs...i.e. low down torque and this will be fine.
Persaonlly I have had only minor gains (2-3%) from header/extractors bolt ons.
true...it is unfair to go bag something without proof. Any how i have ordered the HKS GT2835 with a .87a/r. I also am going to get internal work so will be pushing the turbo to its limits. That being said, with the 20+psi these huffers can get up to, besides the manifold, anything else is going to be restrivtive? I have tomei cams and onli 3"inch to cat and 3.5" there after. That may be a start?
I know kylies manifolds arent tuned length...they are close but not spot on. He made one tuned length and one normal and did back to back testing and found no difference in power, lag, temperatures or back pressure, just abit more added weight to get some of the runners the same length. From what i gather so long as the merge point is seamlessly smooth and doesnt induce turbulence so you get one lot of gas running directly into another lot of gas like in my crappy s/s xsforce manifold then there shouldnt be any problems with it.
My crappy one that ive had for a good year or more stupidly has no.3 running straight up into the collector towards the flange which is great however no.2 comes straight in from the side of the collector runs directly into no.3's exhaust stream. As a result stainless being stainless with its shithouse ability to dissipate heat, that section of the collector and the affected runners localise all that turbulent heat and go white and build up and im getting bad back pressure and its causing my wastegate to fluctuate and when it all gets hot enough its recking my motors power making ability :)
Quick question. Has anyone had their std manifold extrude ported or honed? Whatever you call it. You know that place in Sydney that was doing it to the rb26 factory manifolds, and showing the flow differences between s/s a/m ones and their honed factory ones.
Edited by r33_racer
Yes, I was wondering that as well, I am looking at buying a hks cast manifold low mount, but then started wondering if I extrude honed my std one would that do a similar job for half the cost?
I may even do both ie buy the hks unit and then get it extrude honed.
Have you found some one that sells the hks cast mani for a reasonable price?
I remember when they used to go for 400-600 and then the price began to rise to around 800 then 1000 and then last I saw people were asking close to 1.2k for them. :S
The HKS cast mani could do with some smoothing out as it is cast after all.
When you get a hks mani in your hands and compare it to the std manifold there's simply no way the std item could flow as well as the hks item. Completely different design, smooth merges at the collector etc.
I spoke to the boys at UAS. They are not the ebay crap as stated before. The china ones are 2mm thick and use 302 steel. But all stainless will eventually crack. Street use should last awhile but on track, forget about it. It also comes donw to what turbo you are using. Since mine will be generating 20+psi, the heat would effect it dramitcally. They mentioned the other option on getting the standard one extrude honed. Any idea as to how much this can cost? Any noticeable gains in power? Weighting weather i should bit the bullet and go for a AM one but if i can get similar power from the standard one for half the price...WHY NOT?
wrong
1987 HR31 GTS-R stainless manifold of mine, which is now on a good mates car has done 19 years of diligent service without one crack.
If the manifold is designed correctly, it will last as long as the car itself
$500 or so to extrude hone factory manifold.
If you were to ever get an aftermarket manifold you would want to get it ceramic coated to keep engine bay temps down or expect to melt things... This adds another cost on top of the manifold. Very few of them mount the factory heat shields back on.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
