It means that you jumped onto the bandwagon and bought a cheap r32 skyline.
In all seriousness, it just means that the engine is worn. Most likely compression is low. rb20s are cheap as chips. You can buy them for around 1k.
If the car isn't causing you any problems like bad fuel economy, or stalling or cutting out or anything, you can just leave it if you like until it dies, then get a replacement engine.
If you really want, you could rebuild it now, but a rebuild, even to standard spec, will cost you thousands (probably 4-5k+).
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2680937
i gotta become a pizza boy! must be making good money if you are looking at putting an rb26 in. or you haven't seen the price of doing the conversion.
i'd just wait till the engine dies and put an rb25 in, and spend a bit of money on that.
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2681473
they can tell your engine is tired because the smoke is getting out. Engines run on smoke, and once all the smoke is out it won't run anymore.
A second hand rb20 is pretty cheap if you are worried about it, otherwise keep turning up the boost until it blows up and then put a new one in.
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2681921
i have figured out it will be 10k all up to do the conversion, thats including getting the engine, labour, gear box etc. i get paid a fair bit being a pizza boy around 40k a year on the way i am going. i am just good at saving i guess. but i am still finishing up on the look of my car and suspension. RB26 will be like th last thing. was thinking of the RB25 and having a stroker kit put on. wont be much different wouldnt it??
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2682360
a rb25 conversion done on the same budget as a rb26 conversion will probably get you better performance. and if you happen to blow the motor it is a darn sight cheaper to rebuild. just put a rb25 in, then get a bigger turbo and new ecu and you'll be laughing.
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2682543
rb30 block = slab of beer
n/a rb25 head = $600
rb25 box = $1000
little odds and ends = $500-1000
thats doing it on a bit of a budget, but it shouldnt cost more than that.
its a better/cheaper idea than a stroked rb25, rebuilding it with forged internals would be a good idea too.
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2682743
i've looked briefly at the economy of doing various engine conversions you have a few options.
-Stock rb25det
-Stock rb26dett
-'built' motor add $4k or so
-build an rb24 or rb30 out of your rb20. probably $5k or so, but you have a 'built' motor for close to cost of a stock rb25det or rb26dett. but you are still stuck with an rb20 head which doesn't flow as well as rb25 or 26
rb20 engines are cheap as chips, i have a spare in my garage just waiting for me to blow this one up.... The risk you run putting an rb25/26 in is that the engine you get will also be 'tired'
Edited by MerlinTheHapyPig
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2682783
rb25 box = $1000
I know those NA heads are cheap but dint they have weaker valvesprings then a stock rb25det
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2682817
im not too sure.
like i said thats doing it on the cheap and you wont need to do the oil feed to the VCT with the n/a head.
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2682872
flash89 what are you looking for? there are a few rb20s around making good power if you want to go quicker.
rb25, rb30 and rb26 will get you moving even quicker but they can get much more expensive (in that order)
check out the rb20 thread in forced induction performance
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2683102
dont listen to him. he's blown 6 motors :huh::):)
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2683546
with whatever option you go with it'll be silly not to get new rings and bearings.
yes and no, i mean to do that, take the head off, remove the pistons/rods then if you want to change the crank bearings, take the crank out, then maybe give it abit of a hone, then you have the head off, may as well replace the stem seals while you're at it (since they come with the head gasket kit), give the valves a bit of a lap, maybe you decide to get the head serviced, recut the valves, port/polish etc! it adds up....
once you've reached that stage and fixed anything that is out of spec, may as well do a proper rebuild while you're at it. and you have probably already spent $1-2k if you had this done at a workshop.
Only take the motor apart if you're going to do a proper rebuild, budget $3-4k if you need everything done at a workshop. Of course, it's best to do a proper rebuild, and if you've just bought a motor and it's out of the car, then now is the ideal time to do it.
Rings, rod bearings, head gasket can all be changed with the engine in the car, if the second hand motor is running well and has good compression, and you don't want to do a full rebuild, then don't fix something that ain't broke....
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2684189
the crank doesnt need to come out to do the bearings. you need to do it carefully though. i've changed bearings on cars with the motor still in the car with just the sump dropped with no problems what so ever (checking clearences though).
thats $150 on bearings. rings will cost you another $250ish.
a full gasket kit cost me $160 without the valve stem seals.
and if you REALLY want to do the head, it'll cost around $500 for a full service.
https://www.sau.com.au/forums/topic/143668-engine-tired/#findComment-2684331
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
