i'm looking at putting an electrical water temp gauge in and i'm wondering where to put the sender.
do i remove the stock sender and put it in there?
or do i have to make something up to mount it in and put that in the hose?
if i disconnect the stock one does that stuff up the ecu (make it lose cold start or not control the fan properly)?
thanks
https://www.sau.com.au/forums/topic/143692-water-temp-gauge/
i just had the same problem with mine, bought a new one tryed the std sender but gives faulse readings, the sender that u get with it most likely doesnt fit in the std position(Right?), so im either gona tap in a new thread some where or go down to the exhaust shop an get then to make up a bit of pipe to go in between my radiater hose. either way
doesnt cost much.
i suppose i will have to make something up. getting my hands on stainless piping is no worries. i'll try putting it in the stock location (haven't bought the gauge yet) but if it doesn't fit then i'll make something up.
should i just cut toe standard top hose to fit the adapter in, or buy 2 new bits of hose. i want to try to get out of this as cheaply as possible since its going to be an expensive week for me as it is.
Cut the top hose in two, 12 months ago you could have brought mine!!
I sold it, already had ex temp, oil temp, oil press, boost, reckoned that was enough to distract me lol so sold the water temp and sender.
the main water connector hose has two sensors
one is for the guage in analog style
the other is for the ecu
if you disconnect the ecu one the car may not start and water temp corrections will not be applied correctly, ie: this is a bad idea
when i fried my water temp sensor the car wouldnt start
but when i unplugged the sensor is started fine so who knows.
i was told by a few people there is no chance an rb will start with it disconnected, but it did, so not sure what is right or wrong. but i know the corrections wont apply if its disconnected
If you disconnect the the sensor for the ECU (that's the 2-pin sensor, BTW), the ECU will either regard it as an error and run in safe mode, or it will always think the engine is cold and run with LOTS of fuel.
The sensor you can afford to replace is the single-pin sensor adjacent to the ECU sensor - it is the one that works the temp gauge in the instrument cluster. If you are fitting a new gauge, you obviously don't need that one to work.
the problem is trying to get a sender that fits that hole.
Most temp. sensors are either 1/8"BSPT or NPT.
The Nissan's sensor hole is NOT tapered but is parallel thread with the sensor sealing against a seat cut in the aluminium housing.
There is ample space to drill and tap another thread beside the existing sensors, just take care that no drillings enter the cooling system.
If you decide on that cut top hose system, you must also run a grounding wire to the sensor.
hmmmm, interesting???
jus read that the sonsor shud be on the top hose, mine came with the car wen i got it but its on the bottom hose, is there any logical reason why its there, wat difference wud the top and bottom make??
is it hot engine coolant coming out the bottom hose through the radiator and out the top cooler or the other way???
i tapped my intake manifold right off the head near the coolant outlet, so its the most accurate reading i can get.
alternatively you could weld a bung into the motor outlet/rad inlet for the sensor and that would also provide an accurate reading.
putting the sensor in the hose will make your readings about 4* off of actual...well so ive found on various cars ive fitted them to.
shouldnt make a difference, so long as the sensor, NOT SENDER, is located between the engine and radiator inlet.
The main thing is to know what you're reading. Engine designers usually place the temp sender in a known hot spot, so the reading will be the max.
Big radial aero engines even shield number 1 cylinder from some air flow so that particular cylinder reading will read the worst case.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
