I'm after 2x legal tyres. 1-2mm up from legal would be great. As for size, they are going on R33 stockies so whatever will fit, R16 225 50 seems pretty common. As cheap as possible.
They just have to tide me over until my replacement rims arrive next month.
Thanks
Aaron
Looking for some CHEAP 18" tyres for an event. They are for a V35, and to fit on 18" rims. OEM sizes are 225/45 front & 245/45 rear, so something around there would be good. Rears just need to have a bit over legal tread, would prefer a bit more on the fronts. Let me know what you've got.
Cheers,
Geoff
Hi, I am after a series 1 auto gearbox for an r33 ring/text 0418842599 Thanks, Ryan
I left a S1 autobox at japco when I got them to do my transmission swap, give Frank a call and tell him I said you could have it ! :whistling:
WTB:
-Good condition r32 Gear Boot Leather Thingy.
-Good condition Left hand side r32 aircon vent.
-Good condition cd player/gauge suround r32.
-R32 GTR power fc + hand controller jetro or normal.
Thanks guys.
WTB
Crank Angle Sensor plug and 20cm of wiring (back to around the temp sensor wires)
I broke an air conditioner belt which flicked up, tangled around the thermo fan and snapped the wires that run to the CAS. I need to splice in a new plug and wires ASAP.
Thanks
WTB
Thanks
Give me a ring mate :) 0433368063
They said they don't hang onto used stuff lol, thank you anyways.
Still looking for one, seems that most people throw them away but wreckers want $500 or more... Willing to pay a couple hundred if I can find one if not I will just bite the bullet, thanks.
Edited by 21337
Got an R34 auto. I know it will bolt upto the engine and tailshaft. Maybe do some searching and see if the wiring is the same or similar.
$100
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
