  • Replies 252
Thanks for another great day to all involved. I know what its like standing out in the sun all day as a volunter and I can't thank you all enough.
Looks like I'll have to drag out Riverdance for the next big shep night. Seeing all those photos made me laugh. Man you guys and girls must have had a ball. If only I was there so Stevo many have coped some duct tape treatment. A kind of one off SAU initiation, plus it would have made it easier for Juz to mace him! Only joking Steve, its alway easier to hang shit on the new guy.
Emts your a champion. Everyone's a fan of thier car. Its always great to have some footage so I can show work and mates what we get up to.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
