It has a name....
Behold - The Dongfeng D-120 !!!
Developed with the help of Nissan, Citroen and Honda it features 2.4 litre engine, ABS, Hydraulic Steering and independent suspension.
The D - stands for Dong Feng , Dream and Development, the 120 stands for Dong Feng's production target of 1.2 million vehicles annually (I hope not of this model ;-)
Safety, equipped with SRS airbag, a double-door antitrapping tightening belts and electric windows; Comfort. CD system with eight-inch LCD super, and after stretching, swinging around from top to bottom; cars are also equipped with the tail depends on probe Ergonomics with leather chairs, prudent elegance; top electric car with a sunroof and adjustable shading plate antitrapping Spoiler body and tail support ring smoother transition."
:P
well safe to say i wont be buying that.i mean they are trying to sell to a particular market.for starters there market reasearchers must b on some serious drugs.
A few classic quotes come to mind when looking at thos cars.
"AND PRESENTING THE HOMER!!!" "WERE RUINED" cries Unkie Herb,as he falls to his knees in disbeleif.
"WHATS THE RESALE ON ONE OF THOSE"
the've got to be kidding right...naming the company "mychery"
So,if someone blows one up(and I don't think it'd make it as far as the dyno to go BANG,build quality wise),would that mean they've 'popped mycherry'?!? The next car in the lineup's name may well be 'TheVirgin'...
