Im hoping it will chirp second
Anyway the kkr 530 in basically a 480 with a front compressor the same size as a hks 3037…..Kkr 530 with nokia 1000 rrp
Manifold is g-tech 249 + 35 delivery
Dump has a v ban clamp 180rrp
This is the full setup around the 1500 mark
Funnily the kkr turbo has the same thread as a stock vl turbo gear so all my braided lines bolt straight on
199 for the china wastegate
Anyway ill put her on the silvia and see how long she stands up to 14psi and hopfully 280rwkw
https://www.sau.com.au/forums/topic/144472-cheap-rb30-power-up/
  • Replies 98
pictures aren't quite big enough, i can't make anything out :(
while you probably already know that open collector + split pulse housing is a bad idea from a gas flow perspective, it's a really super bad idea if your turbo-manifold gasket is split pulse as well. it can break off in the centre section and go through the turbine, not a good thing. make sure you trim it down (cut the divider out) if this is the case. it won't be optimal, but it'll do the job.
cheers
ok.. one thing i really do not like.. that looks to be a splitpulse T3 exhaust housing on the KKR turbo.. however your manifold isnt splitpulse.. i wouldnt reccomend running that :S its allright with splitpulse manifold with normaly exhaust housing.. but otherway around has always been a big no no in my opion and many others i know of with vast amounts of turbo experience
might loose some grunt i supose... guess the exaust gass will take the easy way out and might make it a tad laggier.. guess ill find out
or i could put a divider in there .. but lets face it that aint going to happen due to lazyiness
oh and those cases are for my lub's and makup
:laugh:
Given the work/trouble you're going to, surely a day's down time + 100 bucks (depending) to put in a divider is worth it?
Despite the opinions about these units - and my own Garrett type leanings - I'm going to be interested to see how it goes.
yeah lovely pj's you sick bastard. intercooler on the bed ehh... I dont even want to know what the "inlet" looks like now.
get cracking big boy. i need a loaner car for the next skid pay day, and you are top of my list. :D
what was the verdict on the manifold? split or not split.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
