Ive just purchased an R32 gtst. It is the second one Ive owned, the first one was stock as a rock (exept small boost increase) My current one has full lenght 3" exhaust, hi-flow standard turbo, front mount, wolf ECU and 16 psi boost and makes 180rwkw. The thing is it doesnt seem much quicker than my old one. I was expecting to roll on boost in second gear and just start frying the tyres, but it just doesnt have the balls. I have been in another gtst with 220rwkw and it felt real fast. Is 40 extra kw that big of a difference?
https://www.sau.com.au/forums/topic/145738-how-much-power-how-fast/
What you want is torque and power not just power, the more power equates to faster increase in speed? but then again if it feels similar to the old one, take it to dyno and check things out, ie: another dyno different to the one you have been to? 40 rwkws you can feel the difference in yes, why not add cams to your next list or maybe fresh rebuilt and change a few more things.
Thats why your disappointed.
Your expecting things to happen... that... simply wont :)
If you dont expect it to fry the tyres (which it wont) and expect it to have a little more oomph over stock (which it does) then your pretty much aligned with what your car is doing.
I would suggest taking it to a reputable workshop, give it the once over with a few dyno runs and see what happens from there if your worried
40rwkw = 53rwhp, which is a hell of alot different in the same car!
Alot easier to tyre fry with near 300rwhp in a 32 gtst than 240ish thats for sure, 2nd gear tyre fryin is abit over-rated. Traction is much better trust me! Things like tyre choices/condition and suspension are going to influence wheel spin too don't forget :)
16psi is alot for only 180rwkws
yeah thats what I thought. but then again it is only a 2.0ltr engine.
maybe get a compression test performed on the engine, and check things out with a few dyno runs.
maybe look into installing a set of cams, as previously suggested, and then a retune wouldnt go astray.
My car has 260 rwkw and by planting it in 2nd gear unless the road is slippery or bumpy I will not fry the tyres. It just grips.
Also I drove Shonen's R34 with 290rwkw on friday and it grips in 2nd the same way.
Obviously I can fry the tyres on both if I want to but it doesn't happen by accident in a straight line on a good road.
To add to that... poor tunes add to lighting up rears. I lit up the rears before I had the microtech in the S12 by accident all the time... its a rather light car, with very hard suspension and lots of neg camber, so likes to slide.
Used to have a big flat spot due to running rich with stock ecu, this meant it would feel dead then take off like crazy once over 5000rpms... it just felt fast, but really had less power and was less useful.
I think accidental loss of traction is a BAD way of determining power.
it all comes down to tyre quality. i've had tyres that you could fry but snapping 3rd (in a magna) and then put better tyres on that would only just chirp second.
100% agree - power delivery through tahbin type, tuning and right foot position is one thing, but spring rate, shock valveing and tyre TYPE (compound, age, sidewall thickness, amount of wear) play a mighty role
M
You've got about 20 kilowatts more power than me (im using Dunlop SPMAXX's, a high performance tyre with a very soft tyre compound, that grip very well), and i get chirps and more into 2nd, back kicks out pretty hard if the car isn't perfectly straight. My suspension isn't overly hard and it's standard ride height, so dunno why ur not frying tyres, dyno it i spose
He was talking about frying the tyres rolling on to boost in 2nd...not while changing...with the power u have you won't be "frying" your tyres rolling onto boost...but u'll definitely chirp in 2nd...and possibly 3rd...
Get rid of the bloody wolf.....thats problem number one....
2. why do you want to fry tyres while rolling and booting it....is there any really good reason to waste tyre like that?
3. limpus...chipring 3rd's with 180rwkw rb20 = foot still on clutch and cant drive, me thinks :laugh:
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
