Kakimoto is quiet. There was one on the FS within the last couple of weeks. I'd buy that if I still had a car - my favourite muffler for a road car.
Fujitsubo is also known for being quiet.
You might wanna put your setup now - there might be a cheaper way.. i.e. if you have a hot dog and cannon then the easiest way to make it quiet would be putting in a mid muffler, it would be cheaper and might sound good.
Good luck.
Go to your local decent exhaust shop and ask them to replace your rear muffler with a Magnaflow oval muffler and a mid oval muffler also. The noise is made by the internal design of your cannon/mufflers.
I changed from a jap exhaust to a custom cat-back and the difference in noise was astonishing, no more drone, popping or headaches just a constant quiet RB26.
I have a 5Zigen oval muffler & literally cannot hear it over the tyre noise. Dunno is you want it THAT quiet, however.
By the way it has a JASMA plate on it starting with 92-. not sure if the 92 in some way refer to the dBA rating.
Edited by djr81
I had a 3 inch Nismo cat back with the middle 'muffler' and oval rear muffler and 4" tip, picked up 2nd hand for $350 from an importer.
It was as quiet as, prob a little too quiet - i.e. did a 5000 rpm launch with cops on the other side of a van beside me and when they pulled me over they didn't mention one thing about the exhaust, only how fast I took off. No tyre squealing tho(32-GTS4)so that probably disguised the speed of the takeoff a little as well as the quiet exhaust .
Didn't even get a ticket so I am glad the exhaust was quiet.
Edited by gts4diehard
  • 4 weeks later...
I just fitted an HKS Silent Hi Power cat back, i was dubious about the silent part as i could see straight thru it and my daughter could fit her whole arm inside it. once fitted i was impressed, it achieved all its goals.
At idle it still sounds a little herby (i have cams), but on acceleration and deceleration it silences quite well, with little to no restrictions.
overall - impressed.
Most aftermarket systems are over the 90DB legal limit.I have a fujitsubo system.Which is really quiet.
However i managed to get defected for it.It was 94.6DB.The standard system i have on it now is 88.5DB.
The fujitsubo Legalis R system is 89DB at 4500RPM.That would be the system id recommend.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
