Ben,
I have the same LM GT4 (19/10.5 +15).
How did you manage to get your rear wheels to sit so far in/under the guard. My rear rims stick out a lot more than yours.
And I think you mentioned your tyres are 285 wide. What brand are they?
Thanks
MIchael
Hey Mic, now you've got me stumped, as they just bolt on mine! Tyres are Nankangs. Pics of yours mate? I'm interested to work this out.
I need to meet someone with a decent camera! lol Here's mine, snapped with a 2 meg Nokia :laugh:
Nice C-West body kit!
Nismo LMGT4's looks GREAT!
You need a better offset in the rear tho.
More of a Negative offset to fill out your rear guards.
IMO :D
Here's the pic Benny
I'll snap a pic of mine on flat ground in the garage this afternoon. I'll also grab a straight edge try and gauge some measurements re gaurd clearence with that.
It's also worth noting I run close to 3 degrees of neg in the rear.
Edited by Marlin
IMO :D
Thanks mate :laugh: These genuine kits are so nicely made! I was astounded to see the quality compared to our home grown copy stuff.
Without much camber in the rear, the wheel is actually nearly level with the gaurd, but as I've now got about 3 degrees on it, it moves the upper wheel in a little. I small spacer would be sufficient if it bothered me, as I'm not going to order new wheels, they're kind of expensive. I'm led to believe these are also the only offset that Rays make them in 19x10.5. :D
Thanks mate :P These genuine kits are so nicely made! I was astounded to see the quality compared to our home grown copy stuff.
Without much camber in the rear, the wheel is actually nearly level with the gaurd, but as I've now got about 3 degrees on it, it moves the upper wheel in a little. I small spacer would be sufficient if it bothered me, as I'm not going to order new wheels, they're kind of expensive. I'm led to believe these are also the only offset that Rays make them in 19x10.5. :(
If I were to go a full body kit on a R34 GTR, C-West would be the one, with the Version 3 Front Bar. which I think it what you got.
Can't say I am a fan of the silver mesh though...
Or Nismo Z-Tune Front guards and Nismo Body kit is another I would go for.
Ah yes, spacers will help! +1 for that.
I too have a (from memory) 5mm spacer in my rears, just give it that extra fill out.
What offset is your wheels?
Is that the Yokohama ADVAN R34 GTR in the last pic?
As in the Hi Octane Racing one?
That car is Friggin awesome!
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
