that's the wedding convoy we all dream of
congrats man as well
Thanks happened a lil while just haven't got around to getting the photos
Question.
Awesome Friends with same interest in cars to begin with.
Or owners of same car and then became awesome friends later?
Owners of the same car then awesome friends later
Kinda like this:
its more like owners of same car who then meet and have secret phillipino sword fight meetings
Since your car is in the pic. We will have to arrange another secret sword fighting contest soon. nohomo
  • Like 1
Im always ready haha
Yeah we should but problem is I keep loosing coz my sword is too small
sounds interesting :O
If you want to drive gtr weddings you must first be initiated and take on all gtr owners one by one. Only then will you be worthy
LLOL if this involves my anatomical sword then count me out!!!.........unless you're a female GTR dfriver...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
