  • Replies 392
yeah andy time to put ur money where ur mouth is boy. after the dyno all thats left is just the racing :)
My mouth isnt the one that is constantly open
I will say in for now, and I am gonna need a * too .....probably
Apologies if that particular weekend doesn't suit you Warren/Isaac ;) Unfortunately this change was completely out of our control - as Col has already mentioned, Richard is moving premises (better location, better workshop, and he will own it!) so Allstar won't actually be available for the event on the originally planned date. Hopefully we'll see you both at the next one!!
As for everyone else, hopefully the extra month's notice will give you time to organise things around the event, or sort out your cars, if you wish to attend. Remember that if you use Allstar for your mechanical or tuning work, the move will probably affect their ability to do that too!
A very big thumbs up to Richard @ Allstar for accommodating us so soon after his move :)
Thanks for your kind words Marc...
Yeah its great of Richard to bend over backwards to make this happen for us all...
thumbs down to the events team
Sorry Warren, mate we have worked really hard to make this event happen but unfortunatlly Richard is moving and the new workshop offers better facilities to run the dyno day plus the extra support from the tyre mob next door will help our members also in the future...
So he is moving the weekend that the event was originally happening, there is nothing we can do to retain the 20th of Jan, so this was the next best thing... Not to pass the buck or anything, but its out of our control mate... It really didnt have anything to do with the execs...
Once again sorry, but we cant plan events knowing everyones calander. We just need to pop events up and let members work themselves around the event. Its gonna be impossible for us to make it 100% suitable to everyone. But if it helps you cann still get a power run on Richards dyno for $40 as advertised, just PM me if you would like the offer.
It is never too late Isaac but as the list is filling fast, it would probably be better to say yes now and if you have to pike due to work, then remove your name at that time. We have a reserve list for this very reason.
Arhhh bit also remember that you need to transfer your money to the SAU bank account to lock in your position...Its good to do it this way anyway, if your like me and paid monthlly you can pay between now and then when you got $40 or $50 spare and then not have to worry about it again...
Works for me... :)
SMR33 will update the paid list on Monday some time...
im happy to put money down but i dont like piking if it can be avoided..
consider me in then, i'll pay as required and notice will be given between the 8-10th jan :) if i cant make it i'm hoping the position could be sold on to someone else
if everyone on the list has already confirmed that they can make it on the 20th of jan, was it considered to change the venue rather than the date?
its a more logical choice in my opinion...
oh, and thanks for th offer of the dyno run, col, but i don't need one, i was going for the event not for the dyno number per se
and i do appreciate that the was changed because of allstar, but i personally don't care about allstar, i care about the majority of hte members of SAU who have already confirmed that they can make it on the initial date
We understand Warren
In short the fact is there are no shops around that can facilitate our requests and our pricing with a 3 week lead in time...
It all balances out tho as there were members who could not make the 20th of Jan and can now make the 24th of Feb...
Not much we can do its really out of our hands... We cannot call the event off all together, the reloaction of date is by far the easiest thing to do...
NOTE: The next cheapest shop that would facilitate a Saturday dyno day wanted $2200inc GST as a deposit before we even started to run cars... So at 40 cars thats $55 each... They would not let us hang banners and would not allow any of our sponcers there for the event... So Richard has the best offer for us "the club" in terms of cost and support...
It's OK, I can make the 24th....all of those people that just wanted to come along and see me can now go with the security of knowing I will make an appearance. Signed photos will be available, I'll also be autographing my latest book.
Thanks fans! <3
Thanks fans! <3
HAHAHA You crack me up Dan... :P
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
