  • Replies 392
Well the splits wont but my new turbo will... :rofl::)
:huh::laugh::P:)
you serious?! thats not fair!!! the conditions of the show down clearly states it has to be a rb20det with a stock turbo!! :mad:
i might come along and spectate, i had mine dynoed a few months ago.
I got 160rwkw @ 10psi
ah cool nice bench mark - ill see how i go...
Edited by ZENNON
;):no::(:O
you serious?! thats not fair!!! the conditions of the show down clearly states it has to be a rb20det with a stock turbo!! :)
yeah i was quite suprise....but it is set a 14-15psi...but it wont hold it for some reason. so would of had about 180 or so if it held it....stupid turbo.
hey there should be in i think just have to get the money together but shouldnt be a problem will be interesting to see wat my 33 gts25t can do cos i havent had it long and it hasnt been on the dyno yet, not expecting too much though as it only has a 3 inch cat back exhaust im pretty sure and turbo tech boost controller on 9.5.
Officially count me out :) I've got a full-day lecture at Uni on the Saturday.
I understand Dan, your pulling out cause of the taunts you recieved by other R34 owners and you dont want to put them to shame... I support your choice and will make room for you when you decide to return...
Yeah Matt your in, you have until the 2nd week of Feb to transfer the money anyway so plenty of time to save the money...
Dont forget its not to late to join the qld club also, this way you will recieve the run at the discounted price and a free snag and drink...
So if you join just before this event you will save at least $15 already, so really membership is like $40 if you think about it, not to mention the discounted events up and coming this year... Really my membership is free when I think about the use I have had for mine...
Col you wouldnt happen to be a salesperson would you?
Yes
have you started your mods yet col ??
Yes, they are allmost finished... I just have cooler piping and the tune to go...
The engine is all back together and the dump pipes were finished yesterday, for an excelent price i might add...
Haha you mean you heard a sigh of relief from the other boys, they fear the pwning of my car :)
Look fingers crossed they give me credit for the course and I don't have to go, but 1 Saturday compared to 13 x 170kms worth of trips over 3 months = a saving of over $350 in fuel :D
That'd cover the rest of some new injectors and would see me in the +250rwkw zone :)
HackerX
Your added to the list...
Yeah join for sure before the 2nd week of Feb... As i said eariler its your first chance at a discount and some freebies, so its well worth it...
Also have a read of this thread > http://www.skylinesaustralia.com/forums/in...howtopic=104137
This will assist in your membership, if you have any further questions please feel free to PM 'SMR33' as she will take good care of you...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
