  • Replies 46
Bugger aero cD rating crap,fuel economy for the missus and 9 kids,tyre wear,socially acceptable in-car noise levels...Bring back the R32!!! OK,so I'm biased. So I say the 'new' GT-R is the better looker,but neither really has the WOW factor.
And I hate anchovies. There's something not right about a hairy fish...
You dont see it in these pix but from the side its theDodge Viper concept car from 5 years ago...angled belt line, C pilar blown out into the rear guards... reference to the 275 GTB (1966)
The Skyline looks more like a Chris Bangle Bemmer, modern as tomorrow...prefer the Ferrari personaly
they're both pretty disgusting imo.....yep they've lost it.
i don't know if its just me but i really think cars are getting uglier and uglier as newer models come out.
looks wise i much much much prefer the looks of an r32 r33 and r34 over the new gtr.
same with ferrari, give me a 355 over that thing anyday of the week (looks wise).
on another note, i can't believe people are even comparing a skyline to a ferrari, i don't care how good the new gtr is it will ALWAYS be a nissan.
meh just my opinion....
Bang for buck : GTR > Ferrari
Probable superior track time: Ferrari > GTR
Chick pulling power: Pretty close. If you like the italian girls, get the pony, if you don't mind the asian persuasion, GTR is the car.
Either way, you'd get attention. And realistically, how many of either car will be driven anywhere near their potential? Most of them will be baubles or at most see a squirt on the freeway once in a while.
(Dubai and Germany excepted)
That ferrari is hot sauce, bit quizzical about the rear lights something more traditional like the 360 would go down better me thinks, but they could grow on me I guess :(
Definitely think those lights would look better even ofset sizes and positioning like the red one in the original post just same style as the 360, inset etc.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
