A mate of mine went down and had a chat about some work he wants done to his R33 at the Hills motorsport workshop located in Castle Hill, in the block of units where the UAS building is, or used to be. He thought he sounded like he knew his stuff and was a pretty good guy to talk to, I'm thinking of going down there myself to check it out.
Just wondering firstly if anyone else has had anything to do with them and can comment on their experiences in terms of price and workmanship?
Edited by mlt15e
https://www.sau.com.au/forums/topic/148519-hills-motorsport/
ive talked to Mark one of the owners when i bought some stuff off them. great guy and easy to talk to (i dont know about his mechanics workmanship though). ill be heading down there in january to get my turbos in as they charge prettty cheap as well (almost half price of what other shops were charging).
My Dad's been around 'forever' in the car scene, and he thinks highly of them.
He's not had any work done there, but they are friendly and happy to share anything they know. They can't be too bad.
So that's what I know about them.
Go somewhere else! Sure he might be a nice guy to talk too.
Theres also a reason that he is a lot cheaper than other places.
Go somewhere else!
What do you mean by that? Please dont hold back here!
i have had some very negative experiences there. but that is just my experience. i personally wouldn't go there again. there are plenty of other workshops around.
What happened exactly? Im thinking of getting a second hand PFC off him and a tune,
Edited by mlt15e
Friends of mine have had there car's serviced and worked on there.
From there experience the workmanship was fine it was just realy realy slow!
THey have extended there workshop to next door as well now.
I only go there to use there dyno so I dont know what there like personally working on cars.
But they do sounds like they know what there talking about, and there pretty cheap also.
Cheers
Josh
such as...
Plenty of stuff ! getting money upfront for parts and still no parts 3 or more years later and no refund ! plenty more stuff i can pm you with more if you like . I wouldnt trust him as far as i could kick him ! is that honest enough ? Only trying to save you money and hassle .
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
