Just picked up a set of Sard 550cc injectors off a mate.
Bought the sard set due to a convenient price not
as a result of the Nismo vs Sard debate on my other thread... :P
Now like the other thread has anyone used these and
fitted them on themselves?
So far im aware that the O-ring set that comes with
them is no good.
Is there any other issues or dramas anyone has come across whilst
installing these injectors.
Collar set looks odd but hopefully it bolts onto the fuel rail.
Any help with this will be much appreciated.
I'll write a DIY in the tutorials as soon as I get a
chance to fit them on.
Cheers,
Bill
https://www.sau.com.au/forums/topic/149084-sard-550cc-injectors/
Hmm thats weird cause a lot of ppl have told me that cams and injectors can be tricky and would be better left to a tuner to install them
Its depends on how much mechanical knowlegde you have.
Im a 3rd year Aerospace Engineering student and I have been
playing with turbos since I was young.
My moto is: If someone else can do it, well so can I.
No one is born with knowledge...you attain it.
With this mentality anything is possible!
Kind regards,
Bill
Edited by Nabil
Kind regards,
Bill
mr aerospace engineering
I have them installed
the o ring is shit doesn't even fit - not on mine anyway....I had fuel pissing out everywhere...
I adapted the OEM o-rings...works a treat. They are a bit noisy but I only have stock ones ot compare them to...I run over 250 and they never get over 80% duty.
Great...who sells new OEM rings?
As nissan apparently only sells them with the injectors.
Not too keen on re-using my old rings.
Give him a break. I've done the injectors before, and they're piss easy.
All you need is a brain and common sense. e.g. ttake this off, then what is the next logical step. Then do this etc etc.
Shit, fuel is pissing out, obviously i'm gonna turn the engine off.
For f@#$K sake fellas I have done
it before on a CA18 with top feed injectors.
Its my first time to do a RB with side feed injectors.
& I don't believe this "DIRECT BOLT-ON" crap that goes around.
All I ask is for is other peoples anecdotal experiences in
issues they have come across, not a step by step guide.
This has turned into a Comedy Show. ;)
lol agreed mate. Good luck getting a straight answer :P
ive fitted several sard injectors to rb25's. 550cc and 850cc types. I used the orings they provided and had no dramas at all with leaking fuel. No dramas with fitting the collars. The only thing that wasnt bolt on was the plugs. Every set i did had to have the plug cut off the injector loom and rewired to suit their plug. However ive been told that this has changed recently and their plugs are now straight plug n play with the std loom. But i dont know how old your injectors are.
Fark it was hard work....im just a dumbarse fabricator...what would i know about mechanics???
P.S You dont goto workshops...cause they are just as bigger dumbarses as anyone else...haha even mechanics and mechanical engineers. It's really quite sad.
Edited by r33_racer
Honestlly
I paid the extra $$$ and bought Nismo 550's this time as they are true bolt in...
I used Sard in the past on my first 33 and they leaked everywhere, none of the injectors sealed and I could not get the OEM rings on without breaking them... I ended up selling them and buying a fuel rail and top feed injectors, it was a bit of a nightmare to be honest...
yes as Col said already...if i was doing it again i would have gotten nismos also. A true straight bolt up set.
yeah I reckon if I was doing it again I would get the NISMOs...but as I got mine for free, including install etc I went was the Sards...and eys the plugs needed changing also..
They work fine once the o-ring issue was sorted out...dunno if they just gave me the wrong ones...kinda ghey for 600 dollars.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
