I just made templates of the old windows from floor lino, and texta outlined them onto some plastic sheet, then cut with a saw, bandsaw works best, jig saw will cause it to break very easily
probably a wiser idea to use lexan, as its less likely to crack and break like plexiglass/perspex will
not sure on what lexan is per square meter tho
Hmm i need to find a place that specialises in this, and just send them my windows.
How much weight did u loose? 5kg total?
  • Replies 105
There was some threads on this awhile ago, some place in europe can make them. I think they were about 1500 from memory.
I would pay upto 2k for one, and will try and investigate it some more when its time. If its just a matter of giving them some measurements it might become a possibility.
im thinking of having the sunroof remade from plastic too.
I want to do this to the Cefiro eventually. For weight of course, and slightly lower center of gravity. If you don't mind loosing function of the sunroof you could save a few more kg's removing the motor and rails.
Also all glass is concaved... It's not as easy as making a template and wah-lah. If you want to do it properly at least.
Hopefully there is some place that specialises in it, then i could send them the windows and sunroof, have the plastic ones retinted and put them back in :happy:
For some reason, every car that i've ever weighed on a weigh bridge has always weighed significantly more than the quoted weight. They don't have fully sik subs or anything, but for some reason, they all weigh a bit more.
Edited: I know why. A lot of the stuff you mentioned wasn't on the car that they originally weigh. e.g. driving lights, floor mats, stock spoiler is lighter, no sunroof etc.
I'm not sure how the weight is quoted, but is that full of fluid, full fuel tank etc?
Edited by MANWHORE
yes but not
on the side windows, the curvature of the glass is pretty minute, a flat piece of plexi works fine, this will apply for 2 and 4 door models
the rear window is a different msatter, and will require a custom job, you can get them out of japan tho, at some insane amount
you CAN NOT replace the front windscreen with a plexi glass unit, in nearly every catergory of cams recognised racing, the only exceptions i can think of off hand, are sports cars, drags are again different, but from memory, there is also a rule requiring glass in most normal tin top classes.. <by normal i mean somnething that isn't a full tube chasis car>
Aren't weight bridges meant really for larger scale automotive vehicles?
Go to a decent suspension place, get em to check heights, then get measurements with corner scales; progress from there.
I too am in a process of moving easy weight to the rear if i can. HICAS, batt, wash bottle cetra.
Happy stripping
- M
Edited by GeeTR
Most of the weights quoted by manufactures are dry weights, no fuel etc. So if you happen to weigh your car with some fuel in the tank thats why it will be heavier.
The way i worked out my old cars weight was to go and fill the car up with fuel untill it cant be filled no more (the stock r32 fuel tank holds 65litres so i have been told) then put your car on the weight bridge (make sure there is nothing in the boot etc) ,mine came up as 1390kg. the car had a full tank of gas and some heavier than standard 17" wheels and tyres, i have also been told that 1litre of pertrol = 1kg so subtract 65kg's of weight for the 65 litres of fuel in the fuel tank, which would bring the weight down to 1335kg, take away another say 4kg for each aftermarket wheel and tyre as they are quite a bit heavier than the standard wheels, so thats another 16kg of added weight over the stock figure.
1390kg full tank -65kg for 65litres of fuel -16kg for the aftermarket wheels =around 1320kg which is pretty much bang on nissans quoted weight :(
Edited by nizmo_freek
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
