Hi Guys,
Found this awesome documentary which includes in car footage of the Top Secret GTR doing a 0-300 run on Japanese Streets and a hot lap of the Nurnburgring in a Pro Spec R34 GTR (MY BAD NOT A Z TUNE) with Dirk Schoysman who set the original production car lap record in the R32 GTR. Well worth the download. There are not a lot of seeds but I will be seeding the torrent on a 1mb upstream connection in Sydney so you will get a decent throughput. More downloaders means better speeds so keep it seeded guys!
http://www.torrentspy.com/torrent/435015/T...line_GT_R_Story
:cool:
Edited by Chris_R33GTSt
https://www.sau.com.au/forums/topic/149350-awesome-skyline-documentary/
already got that video - there was another one on you tube, some guy was going hard on the ring with the gtr - truly awesome! But that prospec gtr is just unreal. I read that shen was selling that or he already sold it - to make way for his next project or something....
That car has some phenomenal braking power. Dirk takes it from about 250 to about 100 to go through the hairpin in a few seconds.
If anyone else wants it let me know. Ill probably seed it for at least another week. You should be able to get at least 30-50 KB/s off me.
Iv had the dvd for a while, it was a great doco and some mad skylines. Though only thing that was cutting into me was the narrator. lol pommies.
On the dvd it has a special with just the camera shots and another two, three laps of the circuit, and the only talking is done by the rb26 as he puts it through the paces. I could sit all day and watch it.
ps, im pretty sure the 34 aint a ztune (nismo) cause the dvd was realesed in 2003. Puts out some power still
My bad mate! I was a bit pissed when I watched it originally and could have sworn... Lol its about 700Mb and i'm going to keep seeding this because its an awesome piece of info to pass onto your SS Falcodore loving neighbour. Now put that in your peace pipe and smoke it :laugh:
1k/sec
Hmmmmmmm no comment for the 4+ aussie seeders
EDIT: OMFG im such a n00b lol for some stupid reason i had 5 d/l's going and was wondering why i was still only getting 4-5k/sec, cos thats what i had limited uTorrent to :S
Now im gettin 500k/sec, much better! bout 50k/sec from the Skyline vid.
Edited by MADGT4
Awesome, downloading now - Will seed for ages!
Hi fellas,
I'm a torrent noob and don't know what I'm doing. I just spent 12 hours downloading the torrent and now it's seeding?? What does seeding mean as it doesn't seem to expalin it very well in help? I think it means people are now downloading the torrent from me??
Also how do I watch the movie now as I don't want to do something wrong and lose my movie.
Cheers
Ok worked it out - an amasing watch at the Nurnburngring at the end - that driver is so on the ball - didn't think too much of the pommie beginning though. If we did those speeds on aussie motorways you'd be in goal!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
