  • Replies 2.1k
Posted Images
any one here going to the f1? (sorry if there is a thread somewhere else)
my mate from the uk just got a job for McLaren so he's going to be over for the race, so i might head over for the weekend :spank:
haha awesome, what type of job did he get with them?
geez- Webbers well off the pace. But then, so is Coulthard. Chassis, engine package or aero deficiency at Red Bull Racing?
Well no seamless shift gearbox doesn't help.
Also, they have a heap of work to do on the aero.
Engine should be the best in the business
Chassis - well I am not sure they make much difference any more. There is basically no front suspension to speak of. All of them have massive torsional rigidity. With a Renault engine the weight distribution must be good. Only think left is the rear suspension. So, who knows? Hopefully Adrian Newey.
Williams havent been looking that bad so far in testing. The past few seasons there cars havea lways seemed to be in the top 6-8 for the first few rounds. Heres to hoping Wurz gets the job done.
As for RBR, well lets hope they are looking big picture and just gathering data and havent really tried their qualifying setups yet.
Yeah, having Newey as head aerodynamicist, you would have to assume the aero is tip-top. Maybe Ferrari supplied them with a slightly 'modified' customer engine :O.....:kiss:
The progress of the aero has been hampered by them having to move/change/stuff around with their wind tunnel. So they are taking pain in terms of progress.
By modified, do you mean complete with Renault badges?
The only times that should be considered are the times given in the last 5mins of the 2nd session of qualifying at Melbourne next month. Everything up to then is just hogwash.
But someone has to be declared winner of the F1 summer series. :kiss: Inevitably one of the teams runs wonderfully well in testing & then when they rock up to the race the speed has suddenly gone missing. Arrows used to do it really well.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
