  • Replies 2.1k
Posted Images
quote of the day...
Considering how much Honda pay Jenson Button you'd think he might be a bit more positive after races. Jenson, mate, nobody really enjoys seeing a ginger beard up close, so make it easy on us and say something less whingey while we're shielding our eyes. You may have a boss who speaks with all the boyish optimism of a Christian Youth Leader, but that's no reason to take the opposite tack.
You don't have to call the car crap - we can see it's crap.
We were standing next to these 3 yobbo piss heads watching the race....for some reason they thought Webber was 3rd/4th the whole race....was f**kin brilliant when the commentator on GP radio could be heard to say 'and Webber is in 13th...'
Just got my hands on a sample mkv file of what i'll be watching for the entire 2007 season (itv telecast).
It has 4 independent windows, top left is camera angle 1 (its blank for the screenshot only - don't know why) bottom left is camera angle 2, top right is track info (temperatures, location of cars, track status etc) and bottom right is the timing page with driver positions and sector times etc.
Probably the most fascinating way of watching the race, just means i'll have to watch ch10's coverage first then this format 2 days later (takes that long for the person to create it).
"By the second half of the race Giancarlo was already in the hotel," Briatore is quoted as saying by German specialist magazine Auto Motor und Sport. :dry:
Looks like he is surprised their season opener was bad...guess how the rest of the season is going to go with a Rosberge esque rookie and a delicate Roman :)
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
